  question about replacing front lower ball joints
question about replacing front lower ball joints by blacknblue
Started on: 09-16-2013 09:21 PM
Replies: 5 (1150 views)
Last post by: Patrick on 09-17-2013 06:00 PM
blacknblue
Report this Post09-16-2013 09:21 PM Click Here to See the Profile for blacknblueSend a Private Message to blacknblueEdit/Delete MessageReply w/QuoteDirect Link to This Post
So, this might be a dumb question, but Haynes/Chiltons and Pontiac service manual seem to say that I'm not going to change a front lower ball joint on my 87 duke...
Looks to me like they're all saying to change the entire lower control arm. I'm sure I've seen a topic inluding replacing the front lowers somewhere, or is it a better idea to just change the whole arm? Sorry I'm not much of a suspension guy
jb1
Report this Post09-17-2013 04:09 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
rent a ball joint press from autozone , press ball joint out the bottom..
87 GT
(series II swap in progress)
85GT Northstar/ 4t80e
86GT 3800 n/a
My Build
TONY_C
Report this Post09-17-2013 08:49 AM Click Here to See the Profile for TONY_CSend a Private Message to TONY_CEdit/Delete MessageReply w/QuoteDirect Link to This Post
You cannot buy a new A arm/ball joint assembly. You have to press the old one out. Look closely because I have had some that were tack welded in on the underside of the A arm. If so, you have to grind/chisel the weld bead off first.
mike-ohio
Report this Post09-17-2013 04:55 PM Click Here to See the Profile for mike-ohioClick Here to visit mike-ohio's HomePageSend a Private Message to mike-ohioEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is a good write up in the “FAQ’s and How to” section:
https://www.fiero.nl/forum/Forum9/HTML/000007.html
I just purchased some from Rodney and replaced mine.
The only additional note I can add is the ball joint press is designed to crank from the bottom when removing the ball joints. If you are up on jackstands in the garage like I was there isn’t enough clearance for the “screw in” section of the ball joint to press because it will hit the floor. I had to put a spark plug socket on top of the old ball joint to press it out and have the “screw in” section of the ball joint press at the top.
blacknblue
Report this Post09-17-2013 05:22 PM Click Here to See the Profile for blacknblueSend a Private Message to blacknblueEdit/Delete MessageReply w/QuoteDirect Link to This Post
are the ones from Rodney better than Auto Zone or some other supplier?
Report this Post09-17-2013 06:00 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
They better be. I just replaced all four front ball joints in my '88 Formula with units from Rodney, as reported Here.
[This message has been edited by Patrick (edited 09-17-2013).]
