  Electrical Problem
Electrical Problem by AL
Started on: 09-15-2013 11:50 PM
Replies: 4 (146 views)
Last post by: theogre on 09-16-2013 05:00 PM
AL
Report this Post09-15-2013 11:50 PM Click Here to See the Profile for ALSend a Private Message to ALEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I'm driving my 84 my headlights start to dim and then go bright and at the same time my rpms starts to go down and my battery gauge starts pegging to the right and then it all goes back to normal and then it comes back, I've tested the alt and it seems its charging fine, also I don't get any codes, any ideas.
trotterlg
Report this Post09-16-2013 12:41 AM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Likely you have a ground or battery cable problem, there are several ground wires and battery wires and connections you need to check. Larry
Slowbuild
Report this Post09-16-2013 02:11 AM Click Here to See the Profile for SlowbuildSend a Private Message to SlowbuildEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check your alt belt tension is it happens when it's wet out. It'll slide causing a momentary loss and regain in voltage.
Chay
AL
Report this Post09-16-2013 08:52 AM Click Here to See the Profile for ALSend a Private Message to ALEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ill check my ground wires today and connections,checked the alt belt tension and it was good.thanks .
Report this Post09-16-2013 05:00 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dieing alt.
Bad power/ground to/in front.
dieing HL or HL dimmer switches
Start at See my Cave, Wire Service and Alternator Sense
