  Need help diagnosing a buzzing / humming noise coming from behind the Center Console
Need help diagnosing a buzzing / humming noise coming from behind the Center Console by JohnWPB
Started on: 09-14-2013 04:23 PM
Replies: 4 (219 views)
Last post by: phonedawgz on 09-15-2013 07:14 PM
JohnWPB
Total ratings: 144
Report this Post09-14-2013 04:23 PM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Helping a friend try to figure out what is making a pretty loud buzzing noise coming from behind the A/C controls.
- The A/C only blows out of the defrost vents, no matter what button is pushed in. The MAX & NORM do work, as you can hear the airflow increase when you select MAX and it recirculates the air.
Here is a video of as close to as where it is coming from that I can determine. You can definitely hear the buzzing in the video:
Any help figuring this out is much appreciated!
rogergarrison
Total ratings: 551
Report this Post09-14-2013 05:12 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
My first guesses would be alternator noise in the radio or the fuel pump. That dont really sound like either and they wouldnt change by pressing on it. Next guess would be the heater/ac fan, but you said it runs fine ...except it dont blow out the floor. It might be the 'motor' or relay that moves the distribution door. You might try to see if you can force the door that directs the heat to the floor to move one way or the other. Something might be stuck in the opening, jamming it. I know for a fact mice love to crawl into car heater boxes.
FIEROFLYER
Total ratings: 180
Report this Post09-14-2013 05:14 PM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like the motor for changing the heater from one setting to the other is stuck or the motor is cooked
JohnWPB
Total ratings: 144
Report this Post09-14-2013 05:15 PM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yea, the first thing I thought when I heard it was alternator noise in the radio as well. That has been ruled out, as well as the fuel pump. The pump comes on for a couple seconds when you turn the key on, and turns off, as it should.
There is a relay that controls the door to direct the air to defrost, floor, vents? That could be the culprit. Does anyone else know for fact that the relay is located in that area, and that it could make that noise?
Total ratings: 291
Report this Post09-15-2013 07:14 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Blower door motor.
