  Fuel enconomy and trouble codes
Fuel enconomy and trouble codes by Turrent
Started on: 09-13-2013 05:26 PM
Replies: 3 (162 views)
Last post by: fierosound on 09-13-2013 06:02 PM
Turrent
Report this Post09-13-2013 05:26 PM Click Here to See the Profile for TurrentSend a Private Message to TurrentEdit/Delete MessageReply w/QuoteDirect Link to This Post
Alright a week ago i was getting 12.5 mpg. After heeding some suggestions here I replaced the plugs wires, tps sensor, O2 sensor, Ignition Coil, and installed new grounding wires. Currently codes i have 12, 13, 21, 44. Now I did loose one code for broken tps but still have an error for it. Now i will say the stuff i was suggested has improved the fuel economy quite a bit. I'm sitting around 19.8 mpg ish to 19.5. No trouble light comes on while i'm driving though i would like to know if there is more i can do to get rid of these codes in memory not sure if they're even relivent
92wastheyear
Report this Post09-13-2013 05:55 PM Click Here to See the Profile for 92wastheyearSend a Private Message to 92wastheyearEdit/Delete MessageReply w/QuoteDirect Link to This Post
What engine/tranny have you got??
Turrent
Report this Post09-13-2013 06:01 PM Click Here to See the Profile for TurrentSend a Private Message to TurrentEdit/Delete MessageReply w/QuoteDirect Link to This Post
1986 se 2.8 l v6
fierosound
Total ratings: 286
Report this Post09-13-2013 06:02 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Disconnect power for the ECM to clear the old codes.
Near the battery there is a small wire with what looks like an inline fuse.
Disconnect for 15 seconds and re-connect. ECM codes will be cleared.
You now have to drive the car 20-30 minutes for the ECM to relearn.
Calgary time/temp
