  fiero sensor(s) GM part #?
fiero sensor(s) GM part #? by fierogt28
Started on: 09-12-2013 11:22 PM
Replies: 4 (393 views)
Last post by: lateFormula on 09-13-2013 04:48 PM
fierogt28
Report this Post09-12-2013 11:22 PM Click Here to See the Profile for fierogt28Send a Private Message to fierogt28Edit/Delete MessageReply w/QuoteDirect Link to This Post
Need some help tracking all the sensors for the fiero with the GM part numbers?
If anyone can give me the correct part # for the 88 V6 fiero engine, it would be nice.
-Coolant temperature sensor
-Engine temperature sending unit (located next to the coil, in cyl head)
-Fan switch
-Cold start injector switch (next to fan switch)
-TPS sensor
-IAC sensor
-EGR valve (on crossover pipe)
-88 oil pressure sensor (not 85-87 style)
-air intake temp sensor
Thanks,
fierogt28
88 GT, Loaded, 5-speed.
Bloozberry
Total ratings: 311
Report this Post09-13-2013 08:20 AM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
From the 22P:
'88 Oil Pressure: 10096169
ECM CTS: 25036979
MAT: 25036751
Fan SW: 3040674
CSI: 14084318
MAP: 16017460
EGR: 17110813
Temp Gauge Sender: 25036809
TPS: 10106063
IAC: 17111288
I couldn't find the last two items other than in kits which include screws and retainers.
fierosound
Total ratings: 286
Report this Post09-13-2013 12:35 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Some of the original GM numbers may be discontinued or changed to new numbers.
I find www.rockauto.com is always handy for finding AC Delco (GM) part numbers and others.
It also lets me check numbers against what the local parts store comes up with.
Calgary time/temp
[This message has been edited by fierosound (edited 09-13-2013).]
fierogt28
Report this Post09-13-2013 04:03 PM Click Here to See the Profile for fierogt28Send a Private Message to fierogt28Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Bloozberry:
From the 22P:
ECM CTS: 25036979
MAT: 25036751
Fan SW: 3040674
CSI: 14084318
MAP: 16017460
EGR: 17110813
TPS: 10106063
IAC: 17111288
Thanks Blooze...you always come through for helping others on this forum.
Thanks bud...
lateFormula
Report this Post09-13-2013 04:48 PM Click Here to See the Profile for lateFormulaSend a Private Message to lateFormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
For current part numbers go straight to the AC Delco online catalog: http://parts-catalog.acdelc...g/catalog_search.php
