  Install Throttle body spacer?
Install Throttle body spacer? by FieroGT-987
Started on: 09-12-2013 10:14 PM
Replies: 10 (733 views)
Last post by: FieroGT-987 on 09-15-2013 08:54 PM
FieroGT-987
Report this Post09-12-2013 10:14 PM Click Here to See the Profile for FieroGT-987Send a Private Message to FieroGT-987Edit/Delete MessageReply w/QuoteDirect Link to This Post
Should I install a throttle body spacer? Would most auto shops carry one to fit?
DimeMachine
Report this Post09-12-2013 11:36 PM Click Here to See the Profile for DimeMachineSend a Private Message to DimeMachineEdit/Delete MessageReply w/QuoteDirect Link to This Post
what engine?
84/87 NB, 3800SC, E-85, VS Cam, 2.8 Pulley, 4T65E-HD, HP Tuners, AEM Wideband, Regal GS Gauges, S-10 Brake Booster. 1/4 mile -11.906 at 111.93mph
FieroGT-987
Report this Post09-13-2013 07:51 AM Click Here to See the Profile for FieroGT-987Send a Private Message to FieroGT-987Edit/Delete MessageReply w/QuoteDirect Link to This Post
2.8 stock
Report this Post09-13-2013 08:21 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Why?
What benefit?
What problem would it solve?
Fiero84Freak
Report this Post09-13-2013 08:39 AM Click Here to See the Profile for Fiero84FreakSend a Private Message to Fiero84FreakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Such a product is not going to provide any noticeable gains on the 2.8L. The stock intake after the throttle body is too restrictive to see any gains, thus negating anything you do AFTER where the throttle body mounts.
If you want to see intake gains, you're going to have to modify the stock intake setup or pay for an aftermarket setup (both a lot of $$$$)
[This message has been edited by Fiero84Freak (edited 09-13-2013).]
FieroGT-987
Report this Post09-13-2013 09:10 AM Click Here to See the Profile for FieroGT-987Send a Private Message to FieroGT-987Edit/Delete MessageReply w/QuoteDirect Link to This Post
It has a cold air intake with flowmaster 44
jaskispyder
Total ratings: 205
Report this Post09-13-2013 09:19 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
To be honest, the throttle body spacer will be a waste of money. The V6 engine in the Fiero was tuned very well, and you would be better off with cleaning the exhaust headers and crossover restrictions out. How is your cold intake setup? Is it pulling air from inside the engine compartment? The factory system was a true cold intake.
FieroGT-987
Report this Post09-13-2013 09:21 AM Click Here to See the Profile for FieroGT-987Send a Private Message to FieroGT-987Edit/Delete MessageReply w/QuoteDirect Link to This Post
Previous owner messed up the pipe from the vent to the air canister, somimtook it all out and ran a spectre air filter in place of the canister
n7vrz
Report this Post09-13-2013 11:33 AM Click Here to See the Profile for n7vrzSend a Private Message to n7vrzEdit/Delete MessageReply w/QuoteDirect Link to This Post
So you have a hot air intake system now. Sucking air from the hot engine compartment.
I'd restore the stock unit or install one of Rodney's.
http://rodneydickman.com/ca...th=22&products_id=70
BillS
Report this Post09-15-2013 08:48 PM Click Here to See the Profile for BillSSend a Private Message to BillSEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, why do ignorant owners bugger about with the excellent stock system without bothering to check facts first?
FieroGT-987
Report this Post09-15-2013 08:54 PM Click Here to See the Profile for FieroGT-987Send a Private Message to FieroGT-987Edit/Delete MessageReply w/QuoteDirect Link to This Post
It is true cold air intake... I have heat shield and a hose running from the vent to the opening of the filter head.. Its definitely better than stock
