  TPS/Fuel Question
TPS/Fuel Question by bub9797
Started on: 09-12-2013 03:18 PM
Replies: 3 (100 views)
Last post by: bub9797 on 09-13-2013 09:32 AM
bub9797
Report this Post09-12-2013 03:18 PM Click Here to See the Profile for bub9797Send a Private Message to bub9797Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi folks, I need some advice here. Repaired the fuel tank in my Formula. When I start it up it revs to about 2K before dropping, then dying. Threw code 21, which is TPS. Replaced TPS (80 bucks, ouch!). Same result. There's a chance I mixed up two of the lines when I replaced the fuel tank, but I can't imagine it would cause this problem.
Thanks for any help,
Baffled in PA.
lou_dias
Report this Post09-12-2013 11:32 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
a volt meter can answer that question...
trotterlg
Report this Post09-13-2013 12:59 AM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lines as in fuel supply and return lines? Larry
bub9797
Report this Post09-13-2013 09:32 AM Click Here to See the Profile for bub9797Send a Private Message to bub9797Edit/Delete MessageReply w/QuoteDirect Link to This Post
Larry, There are three...a feed line with two clamps on it and two others, return and vent I think.
