  Im installing new muffler, probabaly a thrush. What are the inlet and outlet? Thanks
Im installing new muffler, probabaly a thrush. What are the inlet and outlet? Thanks by FieroGT-987
Started on: 09-10-2013 11:54 PM
Replies: 10 (417 views)
Last post by: steve308 on 09-11-2013 07:38 PM
FieroGT-987
Report this Post09-10-2013 11:54 PM Click Here to See the Profile for FieroGT-987Send a Private Message to FieroGT-987Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have stock 2.8 1987 gt
Putting on a new thrush muffler. What inlet and outlet do i need to buy? And does it have to be the three hole muffler, one in, two out? Thanks. Im a noob haha
fierogtlt1
Report this Post09-11-2013 12:25 AM Click Here to See the Profile for fierogtlt1Send a Private Message to fierogtlt1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Is the Thrush #17638 ?
trotterlg
Report this Post09-11-2013 12:35 AM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Stock is one in and two out. Larry
FieroGT-987
Report this Post09-11-2013 12:48 AM Click Here to See the Profile for FieroGT-987Send a Private Message to FieroGT-987Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, are you sure its 1 in 2 oit? I saw a lot of different things online, and also, can a mechanic make a 2 or 2 1/2 fit the in by welding or a connector or clamp or something? Or does it have to be exact measurements?
trotterlg
Report this Post09-11-2013 12:52 AM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Stock Fiero is one in and two out, first it goes to the the Cat, then to the muffler and then splits (two out of the muffler) to the the exhausts. Any pipe size can be adapted to any other, but it best to get what your car has now going into the exhisting muffler. Larry
fierogtlt1
Report this Post09-11-2013 12:54 AM Click Here to See the Profile for fierogtlt1Send a Private Message to fierogtlt1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thrush Muffler #17638
Single Inlet. 2-1/2"
Double Outlet. 2-1/2"
[This message has been edited by fierogtlt1 (edited 09-11-2013).]
FieroGT-987
Report this Post09-11-2013 01:12 AM Click Here to See the Profile for FieroGT-987Send a Private Message to FieroGT-987Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks a lot guys!
FieroGT-987
Report this Post09-11-2013 07:43 AM Click Here to See the Profile for FieroGT-987Send a Private Message to FieroGT-987Edit/Delete MessageReply w/QuoteDirect Link to This Post
FieroGT-987
Member since Jun 2013
steve308
Total ratings: 58
Report this Post09-11-2013 11:43 AM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Appears to be the same part # you were given above! You can always measure your old muffler for the "body length" for comparison.
fierogtlt1
Report this Post09-11-2013 12:41 PM Click Here to See the Profile for fierogtlt1Send a Private Message to fierogtlt1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Original 2.8L. Fiero Muffler
12" Length.
9-5/8" Width.
5" Depth.
15" Length.
9-1/2" Width.
4" Depth.
I hope that helps you.
steve308
Total ratings: 58
Report this Post09-11-2013 07:38 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
putting them all togetrher
