  Anything else I should replace?
Anything else I should replace? by wgreen17
Started on: 09-09-2013 09:25 PM
Replies: 3 (107 views)
Last post by: renderareason on 09-10-2013 09:07 AM
wgreen17
Report this Post09-09-2013 09:25 PM Click Here to See the Profile for wgreen17Send a Private Message to wgreen17Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am replacing the following: Shocks and Struts (Monroe), all ball joints and sway bar links from Rodney, and all new Moog control arm bushings. Anything I am forgetting or need to know? I know I will need an alignment after this.
h.d.fire
Report this Post09-09-2013 09:37 PM Click Here to See the Profile for h.d.fireSend a Private Message to h.d.fireEdit/Delete MessageReply w/QuoteDirect Link to This Post
not a bad idea to do the wheel bearings up front and the hubs out back
wgreen17
Report this Post09-09-2013 10:23 PM Click Here to See the Profile for wgreen17Send a Private Message to wgreen17Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am thinking about doing a brake job this winter and will probably do wheel bearings then
renderareason
Report this Post09-10-2013 09:07 AM Click Here to See the Profile for renderareasonSend a Private Message to renderareasonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would also replace the tie rods (inner and outer), front and rear (if you have an 84-87).
