  C500 wire A1, Cant figure out what its for or If I need it?
C500 wire A1, Cant figure out what its for or If I need it? by Jims88
Started on: 09-08-2013 06:43 PM
Replies: 6 (177 views)
Last post by: Jims88 on 09-09-2013 06:08 PM
Jims88
Report this Post09-08-2013 06:43 PM Click Here to See the Profile for Jims88Send a Private Message to Jims88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am working on my LS4 wiring and have this dark green wire on Pin-A1 at C500 connector?
The 88 manual said not used, so why is it there?
Other Pins the manual said aren't used, have a blank spot at the connector.
Any insight would be helpful.
Jim
trotterlg
Report this Post09-08-2013 06:59 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just did this, it is not used, cut it off. Larry
hookdonspeed
Total ratings: 131
Report this Post09-08-2013 07:05 PM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
what DID it goto?
CowsPatoot
Total ratings: 84
Report this Post09-08-2013 07:39 PM Click Here to See the Profile for CowsPatootClick Here to visit CowsPatoot's HomePageSend a Private Message to CowsPatootEdit/Delete MessageReply w/QuoteDirect Link to This Post
On 84s only, power runs from the AC Relay into pin K of the C203, then back out pin A1 of the C500, and to the AC clutch.
There are a few other things different for 84s....you can find the full list here: https://www.fiero.nl/forum/Forum2/HTML/121625.html
[This message has been edited by CowsPatoot (edited 09-08-2013).]
FIEROFLYER
Total ratings: 180
Report this Post09-08-2013 08:24 PM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
Pin A1 on the C500 is for power trunk on the 85 models also. Dan
CowsPatoot
Total ratings: 84
Report this Post09-08-2013 08:37 PM Click Here to See the Profile for CowsPatootClick Here to visit CowsPatoot's HomePageSend a Private Message to CowsPatootEdit/Delete MessageReply w/QuoteDirect Link to This Post
Interesting...I wasn't aware of that one. If that was the case, it would be black/white. The pic is the proper dark green for the AC control on the 84.
Jims88
Report this Post09-09-2013 06:08 PM Click Here to See the Profile for Jims88Send a Private Message to Jims88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank You Guys!
I will just cut it off.
