  Alternator light question
Alternator light question by trotterlg
Started on: 09-07-2013 06:49 PM
Replies: 6 (230 views)
Last post by: trotterlg on 09-09-2013 03:29 PM
trotterlg
Report this Post09-07-2013 06:49 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
OK, here is the deal, I have a Jeep (chrysler) alternator on my 3100 carbed swap. This is because they can be mounted without using a bracket on the engine and they mount down low to clear headers. They are an "isolated field" type, so they use a little regulator, they are very simple to hook up. The thing works great, charges like it should and the volt meter reads right. Wondering if there is some way to make the red light work also with this setup. Larry
Report this Post09-07-2013 08:39 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm not sure how that alternator works with the Fiero circuitry, but pre-88 Fiero, the BAT light in the amp meter display was a part of the charging circuit. If the light burned out, the alternator couldn't charge the battery.
trotterlg
Report this Post09-07-2013 09:44 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
This setup does not use the light for charging, it has it's own little regulator seperate from the alternator. The battery volt meter works fine, it would be nice to have the red light work also, but I don't know how I would do that or how it is wired in. Larry
Total ratings: 291
Report this Post09-08-2013 02:01 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Grab an Arduino Uno. Add a 7805 5V voltage regulator to run it. Also add a 5v micro relay for the output for your light. Then just two more resistors, one 1K the other 4K to give you a 5:1 voltage reduction and use that as your input.
Program the Arduino to double wink the volt light when you first turn the key on as a nice touch.
Program the Arduino to light the light at under 13v or over 15v
Program the Arduino to flash SOS in Morse Code on the light at under 12v or over 16v
http://www.ebay.com/itm/UNO...&hash=item3cd0d45931
You can mount the circuitry on an arduino development shield
[This message has been edited by phonedawgz (edited 09-08-2013).]
IFLYR22
Report this Post09-09-2013 01:02 AM Click Here to See the Profile for IFLYR22Send a Private Message to IFLYR22Edit/Delete MessageReply w/QuoteDirect Link to This Post
If your alternator has an field output circuit (example: Output pin "L" on a GM, CS type alternator), then the light can be wired with that output.
You need to find out what Jeep did to wire it in their vehicles and duplicate it in your fiero. Do you have the pin-out of the alternator you are using?
-Dave
Report this Post09-09-2013 02:09 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yup... Need Jeep book or Alt doc's to see how that Alt is wired. Shouldn't be hard to dup that.
Originally posted by phonedawgz:
Grab an Arduino Uno...
Arduino? A bit of overkill... SOS when over 16v is good.
A simple transistor will drive 12V bulb... 194 draws 0.27 amps.
trotterlg
Report this Post09-09-2013 03:29 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Arduino is good idea, I use them for a lot of other things, I will have to look up how the jeep does the idiot light, but my volt meter works good now. The field is just two terminals on the alternator, they are isolated from ground, you just send power through them to make the alternator charge, you can send it either direction. it uses a little regulator that switches one side to ground to get power through the field, it is very simple and nice to work with, but I don't think it is compatable with the way the Fiero light is set up. Not really a big thing not having the light, but it would be nice to tell if you broke a belt or something like that. Larry
