  88 Formula charging questions.
88 Formula charging questions. by Carver1
Started on: 09-02-2013 01:14 AM
Replies: 1 (91 views)
Last post by: theogre on 09-02-2013 09:44 AM
Carver1
Total ratings: 62
Report this Post09-02-2013 01:14 AM Click Here to See the Profile for Carver1Send a Private Message to Carver1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Before I tear into the harness on this Formula, I wanted to pick a few brains to see where I should start.
The car runs great, but sometimes won't charge.
It has been through a few alternators, and the problem seems to happen shortly after alternator replacement. (a few days to a few months)
The volt light will light up and shows that it is not charging.
Sometimes when you start the car it will charge.
It does not change from not charging to charging while running, only after it is shut off, then restarted.
I am leaning towards a bad harness, ground, or some other connection.
Where to start?
84 Fiero V6 4 speed
11 Camaro SS/RS LS3 6.2
13 Traverse LS 3.6
12 Silverado Z71 5.3
12 Tahoe LT 5.3
64 Lincoln Continental 7.0
Report this Post09-02-2013 09:44 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
maybe Alt wires/socket/etc is bad/loose...
See my Cave, Wire Service, CS Alternator and Alternator Sense
If MIL is on, Check ECM codes for over/under volt too.
[This message has been edited by theogre (edited 09-02-2013).]
