  Voltage issue on 3800SC - P0620 code
Voltage issue on 3800SC - P0620 code by Rare87GT
Started on: 09-01-2013 02:52 PM
Replies: 1 (72 views)
Last post by: MstangsBware on 09-01-2013 03:32 PM
Rare87GT
Total ratings: 173
Report this Post09-01-2013 02:52 PM Click Here to See the Profile for Rare87GTSend a Private Message to Rare87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
For a long while my car has thrown the P0620 code which means the voltage is below a certain number. We tested the voltage on the car at the battery and it shows 13.8-14.2 and the alternator tested fine. My question is, the voltage at the PCM is reading wrong and showing under 12 volts which is causing this code. What is the procedure for testing it at the pcm and why is the computer not seeing the proper voltage? PCM and engine is a 2000 GTP setup.
Thanks guys.
MstangsBware
Total ratings: 459
Report this Post09-01-2013 03:32 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Need to look at wiring diagram and start chasing wires. Find where the power comes from to the PCM and check continuity on wires to see if that is where u r losing it..
