  Suspension question and problem
Suspension question and problem by Sile
Started on: 08-31-2013 11:02 AM
Replies: 4 (178 views)
Last post by: Bloozberry on 08-31-2013 12:19 PM
Sile
Report this Post08-31-2013 11:02 AM Click Here to See the Profile for SileSend a Private Message to SileEdit/Delete MessageReply w/QuoteDirect Link to This Post
So I took my car down a toll road yesterday that's speed limit is 75and of course I do the normal 5 over cruising along at 80 I got to switch lanes and the fiero starts to act like it's going to fish tail so I let off the throttle and ease back after I almost crapped myself.
Not sure what I did I have got my garage cleaned out yet but I plane to stick it in for a while (Have some other things to do. But now anytime I get above 65-70 it gets really squirly and scary it also does it now I've notice when I mash on the gas.
What should I look at and what are some goo upgrades? I was looking at the zero lash sway bar link because I always though the steering was a little to loose. Give me some ideas please withought digging to deep in my pockets lol.
87 fiero gt 5 speed 3800 sc
Report this Post08-31-2013 11:09 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
First thing I would do is check on the tire pressure and/or damage.
TONY_C
Report this Post08-31-2013 11:15 AM Click Here to See the Profile for TONY_CSend a Private Message to TONY_CEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you suspension components are in good shape you most likely need an alignment, having the rear toe out will make the car feel very loose at higher speeds.
gtoformula
Report this Post08-31-2013 11:16 AM Click Here to See the Profile for gtoformulaSend a Private Message to gtoformulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you have replaced suspension parts get it aligned. If you haven't replaced parts check out out everything, replaced what is loose and then have it aligned. I have a 1986 GT 5 speed and had issues after replacing suspension parts. The rear is more critical than the front. Just changing rear rode height (I've got coil overs) change the camber and toe in. It would pull one way whe accelerating and another when decelerating. Getting an alignment straitened it out.
Bloozberry
Total ratings: 311
Report this Post08-31-2013 12:19 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
Most of the time the problem is either with tire pressures or the rear tie rods being worn out. Even a hint of looseness in the steering axis of the rear wheels will give squirrely handling especially when changing the load (accel/decal) on the tires.
Jack up the rear of the car and grab your tires at the 3 and 9 o'clock positions and wiggle hard... any play is not good and is a sign of a worn tie rod (most likely), or a worn bearing (but only if play is also felt when wiggling the tire at the 12 and 6 o'clock positions) or worn control arm bushings (least likely).
