  Hurt to leave non-functional cruise control alone?
Hurt to leave non-functional cruise control alone? by John W. Tilford
Started on: 08-30-2013 08:04 AM
Replies: 3 (497 views)
Last post by: John W. Tilford on 08-30-2013 09:54 AM
John W. Tilford
Report this Post08-30-2013 08:04 AM Click Here to See the Profile for John W. TilfordClick Here to visit John W. Tilford's HomePageSend a Private Message to John W. TilfordEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just realized there may be vacuum leaks involved and just ignoring my non-working cruise control might be yet another stupid thing I do. (88GT 2.8) How important is it to 1) get fixed, or 2) plug holes?
jaskispyder
Total ratings: 205
Report this Post08-30-2013 08:43 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just plug the hoses and ignore the system.
Bloozberry
Total ratings: 311
Report this Post08-30-2013 09:20 AM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
There's only one vacuum feed for the entire system. It tee's off of one of the two metal lines that run along the trunk wall going to the evap canister. The tee is vertical and is really close to where the driver's side strut tower meets the trunk wall. There's a rubber hose that connects from the tee to the solenoid control valve. As long as the solenoid valve works, ie it remains closed and prevents the vacuum from being applied to the rest of your leaky cruise control system, you don't need to do anything. Of course if you accidentally request cruise, then you'll lean out your fuel mixture due to the extra air that the leaky cruise system will allow into the plenum. If you want to eliminate that possibility or if your solenoid valve doesn't work, then the best option is to unplug the cruise vacuum at the tee fitting and stick a short length of plugged vacuum hose on the metal tee stub.
John W. Tilford
Report this Post08-30-2013 09:54 AM Click Here to See the Profile for John W. TilfordClick Here to visit John W. Tilford's HomePageSend a Private Message to John W. TilfordEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like a good idea to cap. There have been several times I'd find the cruise slider switch was "on". Thanks for the tip.
