  84 running rough
84 running rough by shortbus
Started on: 08-29-2013 03:50 PM
Replies: 33 (435 views)
Last post by: Patrick on 09-24-2013 02:49 PM
shortbus
Report this Post08-29-2013 03:50 PM Click Here to See the Profile for shortbusSend a Private Message to shortbusEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am not sure where to start I am helping my 18 year old. We did a motor swap from 2 84's 1 manual aan 1 auto trans. We took the motor out of the auto and put it into the manual. Now we can not get it to run right. With jumper I gat get it to time at 8 deg once I pull the jumper it will bounce from 2500-3000k rmps. I have cleand the egr and new gasket then got a tps code replaced that. The motor ran good befor the swap we moved all vacuum. I am out off ideas.
Report this Post08-29-2013 04:02 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
shortbus
Report this Post08-29-2013 04:13 PM Click Here to See the Profile for shortbusSend a Private Message to shortbusEdit/Delete MessageReply w/QuoteDirect Link to This Post
We used the manual ecu and wiring out of that car so just swaped the motor.
Report this Post08-29-2013 07:30 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by shortbus:
... it will bounce from 2500-3000k rmps.
Sounds like a major vacuum leak. Check all hoses and connections.
Report this Post08-30-2013 09:52 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Possible junk in the fuel system got loose during the swap. Spray a little starting fluid in there and see if it smooths out.
shortbus
Report this Post09-02-2013 05:22 PM Click Here to See the Profile for shortbusSend a Private Message to shortbusEdit/Delete MessageReply w/QuoteDirect Link to This Post
Found 1 vac line bad/cracked replaced all then sprated with carb cleaner and the motor did not rev/speed up at all. It will idle at about 1500 with paperclip in. I do have a code 15 coolant sensor high voltage (could this cause it?
I also tried to cap the pvc and there was no change in the idle?
Report this Post09-02-2013 06:06 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
What RPM does it idle at with correct ignition timing and the paperclip removed?
If the coolant sensor is faulty and the ECM is being told the engine coolant is always cold, yes, I suspect the engine could idle higher than it should.
shortbus
Report this Post09-02-2013 09:47 PM Click Here to See the Profile for shortbusSend a Private Message to shortbusEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for all the input just swapped IAC with the one of the other car purrs at 800rpm's.
The Temp sensors had no impact on how it ran both of them made it run the same(we tried them both before and after the IAC)
But it did throw a TPM code I just put a new one in at the start of this last weekend tried the old one back in still throws a code ( I left the batt dis-connected for 1 hour in between the changes too)
Report this Post09-04-2013 02:07 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Keep in mind there are two different "temp sensors" on the duke, as discussed Here. One is just for the temperature gauge, the other is for the ECM.
But hey, if your problem is solved... great!
shortbus
Report this Post09-18-2013 03:57 PM Click Here to See the Profile for shortbusSend a Private Message to shortbusEdit/Delete MessageReply w/QuoteDirect Link to This Post
ok guys im still having problems im getting a code 15 and a code 21 its like its running with a bad tps it doesn't like to start and runs really bad i have read some where that the coolant code 15 can mess up the fuel system is that true and if so where do i start and i know the tps is good i just got a new one but when i test it comes up as 5v when it is closed it does this with the old one and the new one also if i put the jumper in the computer before i start it then re tune it it runs good until i pull the jumper then it runs bad again also i have replaced the coolant sensor with a spare i had around
Report this Post09-18-2013 04:19 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I addressed this in my previous post. Have you checked or replaced the coolant temp sensor for the ECM?
shortbus
Report this Post09-18-2013 06:32 PM Click Here to See the Profile for shortbusSend a Private Message to shortbusEdit/Delete MessageReply w/QuoteDirect Link to This Post
yes i have replaced it with a second one i had but i think i may have found the problem the one that controls the fan had broken in the swap the wires and the plastic pulled out of it i hope this will solve the problem i ordered a new one to day it will be here tomorrow around noon
Report this Post09-18-2013 07:40 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
The coolant fan switch will have ZERO effect on the trouble codes you've posted.
shortbus
Report this Post09-19-2013 08:22 AM Click Here to See the Profile for shortbusSend a Private Message to shortbusEdit/Delete MessageReply w/QuoteDirect Link to This Post
ok how do i trouble shoot this code then i know its not the sensor i have switched them out with two that have worked
Report this Post09-19-2013 11:29 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Code 15: Infinitely High resistance means a broken or disconnected wire somewhere in the CTS circuit....assuming the CTS is good. Fix this code first.
Code 21: TPS. Most people start with a good cleaning and see what happens.
[This message has been edited by Gall757 (edited 09-19-2013).]
shortbus
Report this Post09-19-2013 04:14 PM Click Here to See the Profile for shortbusSend a Private Message to shortbusEdit/Delete MessageReply w/QuoteDirect Link to This Post
so i assumed the cts was good and tested the wire from the connector all the way to the computer and it was not broken so i tested the cts the two of that i had and i think they are bad in my computer room its like 80-85 degrees and the cts is saying air temp is around 120 (around 1.021 ohms) for both of the cts either i am testing the resistance wrong or they are both bad now being that i have replaced the tps would the cts problem because the tps code 21 to go off and the car to run rough? when i test the old and the new tps i get 5 volts on the black and the blue wire which would mean wot right? and for closed throttle it should be at 1.25 if i have read right in my Haynes manual
shortbus
Report this Post09-19-2013 04:35 PM Click Here to See the Profile for shortbusSend a Private Message to shortbusEdit/Delete MessageReply w/QuoteDirect Link to This Post
shortbus
Member since Aug 2013
also i was going to replace the fan switch today and i had got the wrong one it for was the car with no ac and it wont cross over but i was looking on line and i cant seem to find one on line that is the two connector style at least on the fiero store i can find a new connector if i dont get to it will it hurt to run it with out as long as i use the max ac so i can get the fan on?
Report this Post09-19-2013 04:35 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Stick the end of each CTS into a pot of boiling water and see what the readings are.
shortbus
Report this Post09-19-2013 04:47 PM Click Here to See the Profile for shortbusSend a Private Message to shortbusEdit/Delete MessageReply w/QuoteDirect Link to This Post
i assume i am reading my volt meter correctly because it it reads 1.021 which i would assume is 1021 i hope i right with that?
shortbus
Report this Post09-19-2013 05:08 PM Click Here to See the Profile for shortbusSend a Private Message to shortbusEdit/Delete MessageReply w/QuoteDirect Link to This Post
shortbus
so in the bolling water the one reads .490-.500 which would be 150 degrees and the other one reads .690-.700 and thats like 135 degrees so should i go ahead and replace it with a new one?
Report this Post09-19-2013 05:32 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've always used WinALDL to see what's going on (as oppposed to using an omhmeter on the sensors), but it seems to me from what you've reported that those CTS units are indeed faulty. Perhaps someone can chime in who's more familiar with the method that you're using.
Report this Post09-19-2013 05:42 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
The fan normally doesn't come on until the coolant reaches the surface temperature of Venus, so I wouldn't worry about it.
But yes, you can simply turn on the A/C if you feel the fan is necessary.
shortbus
Report this Post09-19-2013 07:34 PM Click Here to See the Profile for shortbusSend a Private Message to shortbusEdit/Delete MessageReply w/QuoteDirect Link to This Post
ok so i ordered a new cts and sense i blew up the fan switch i tried to get a new one for the one with ac but no one has one that my local part store can find so i got the non ac one and i will have to figurer out how to make it work all of the parts will be here tomorrow so i will up date more probably tomorrow or Saturday when i have time to get the parts in im so hopping this all works i i miss my fiero so much
shortbus
Report this Post09-20-2013 03:31 PM Click Here to See the Profile for shortbusSend a Private Message to shortbusEdit/Delete MessageReply w/QuoteDirect Link to This Post
so i put the new cts in and it made little change at all it still doesn't like to start you have to put gas down in the "carb" from cold start and starts ok from warm but it still putts every once in a while could this be a problem with the new cts or maybe even the computer? and the codes are still there i even disconnected the batt for like 20 min just to make sure all the juice was gone
Report this Post09-21-2013 12:15 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
so i put the new cts in and it made little change at all it still doesn't like to start you have to put gas down in the "carb" from cold start and starts ok from warm...
So this engine supposedly ran fine in the other Fiero? So what's different now? No doubt the fuel, gas tank, fuel pump and fuel filter are different.
How old is the gas?
How much fuel in the tank?
What's your fuel pressure like?
When's the last time the fuel filter was replaced?
...and the codes are still there i even disconnected the batt for like 20 min just to make sure all the juice was gone
Did you actually completely disconnect the battery?
I find it difficult to believe that the ECM has somehow been able to retain the codes with NO power.
shortbus
Report this Post09-21-2013 01:17 PM Click Here to See the Profile for shortbusSend a Private Message to shortbusEdit/Delete MessageReply w/QuoteDirect Link to This Post
i did disconnect it all the way and the car when i started the swap had two year old gas with half a tank so i went out and got two bottles of octane boost and 5 gallons of fresh 89 octane well in running it and cleaning the injector and not seeing the gasket was broke i went threw another 1/4 tank then i filled it with another three gall of 89 octane and the fuel filter is off the one that was running but the pump and all that have been sitting for a while do you thing bad gas or some thing like this could cause the code 15 because originally i was thinking it was bad gas making it do this but then i looked in to the code 15 more so i disregarded the bad gas
Report this Post09-22-2013 02:05 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Your posts would be a whole lot easier to read if you made use of a period (.) between sentences.
Total ratings: 290
Report this Post09-22-2013 07:45 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
You should be getting about 4.5 volts WOT and .5 to .75v closed throttle. Sounds like the black wire has a high resistance problem.
So according to this schematic the TPS and the CTS share the same return (isolated ground) wire to the ECM. That's where I would be looking first. Either a corroded terminal /broken wire in the ECM connector or a high resistance joint where the two wires connect in the harness.
C1 (Blue/Black connector) Pin 11 - Black wire
[This message has been edited by phonedawgz (edited 09-22-2013).]
shortbus
Report this Post09-23-2013 04:54 PM Click Here to See the Profile for shortbusSend a Private Message to shortbusEdit/Delete MessageReply w/QuoteDirect Link to This Post
so with the beep setting on my multimeter i have found that the black common ground wire is good and they do go all the way to the computer. also in testing the tps voltage today i had it disconnected to see if the value would change to make sure there is nothing wrong with the wiring and with the tps not plugged in the reading was .05 on the blue (middle wire) but when it is plugged in i get 5 volts across all three wires. i also tested the resistance of the brand new cts the multimeter read 1.1xx so from the cart that i have found on-line it would be about 120 Fahrenheit and this was with the motor not running at all to day so the coolant was around out side temp of about 70-75. so could it possible be that i still have a faulty cts, or maybe the common ground is not getting in to the computer (i know it gets there but i don't know if it makes it inside of the computer)? also could a possible faulty tps make the cts act incorrectly? i ran it a little bit today and it started a whole lot better (did not need to put gas in the carb) and it wasn't popping like it was before when i ran it.
shortbus
Report this Post09-23-2013 05:34 PM Click Here to See the Profile for shortbusSend a Private Message to shortbusEdit/Delete MessageReply w/QuoteDirect Link to This Post
shortbus
Also after doing some more research i found this ( https://www.fiero.nl/forum/A...100421-2-098589.html ) maybe the ground is back feeding that 5 volts to the cts? Im going to look in to that right now any ideas what to do to the ground if this is whats wrong?
shortbus
Report this Post09-23-2013 06:01 PM Click Here to See the Profile for shortbusSend a Private Message to shortbusEdit/Delete MessageReply w/QuoteDirect Link to This Post
shortbus
So the ground is feeding that 5 volts i assume there should be zero volts on it. Does any one have an idea why it is doing that? What can i do to fix it if it should have zero?
shortbus
Report this Post09-23-2013 09:44 PM Click Here to See the Profile for shortbusSend a Private Message to shortbusEdit/Delete MessageReply w/QuoteDirect Link to This Post
shortbus
so it was a bad ground and its all fixed up now runs like a top after i re timed it thanks for all the help guys
newfiejeff
Report this Post09-24-2013 11:53 AM Click Here to See the Profile for newfiejeffSend a Private Message to newfiejeffEdit/Delete MessageReply w/QuoteDirect Link to This Post
My two cents, I would have chucked the gas from the get go. I just bought a 86 with hardly any gas that was sitting around for a couple of years, put new gas in it and I had a hard time of missing, lack of power, smelly and black smoke for about 30+klms. The car is a whole lot better now, but I will clean the tank, new filter and new gas next spring as it will be parked for the winter.
Bad gas/moisture can sure cause a lot of trouble!!!
Report this Post09-24-2013 02:49 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
My experience with at least three Fieros that sat for years is that old gas is fine... just add some fresh gas to the tank.
However, water in the gas tank is not fine.
