  Tach Problems..
Tach Problems.. by Myrick813
Started on: 08-27-2013 09:58 PM
Replies: 4 (542 views)
Last post by: Ac Fiero on 08-30-2013 12:56 PM
Myrick813
Report this Post08-27-2013 09:58 PM Click Here to See the Profile for Myrick813Send a Private Message to Myrick813Edit/Delete MessageReply w/QuoteDirect Link to This Post
So i have a 86 se v6 auto. Since i got the car as soon as i start the car the tach pegs out and stays there till i shut it off. I figured it was the Tach itself so i swapped in a 120 cluster with a new tach and it dose the same thing. Anyone have a clue what i should check ? BTW what should happen when i unplug the tach filter.
Report this Post08-28-2013 08:20 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
When you unplug the tach filter the tach should not work.....but you can jumper the wires and it will operate with no filter.
Myrick813
Report this Post08-28-2013 10:04 PM Click Here to See the Profile for Myrick813Send a Private Message to Myrick813Edit/Delete MessageReply w/QuoteDirect Link to This Post
So i unpluged it and it dies, I jumped it and it peggs back out . Any suggestions?
Thanks Brian
Myrick813
Report this Post08-29-2013 10:53 PM Click Here to See the Profile for Myrick813Send a Private Message to Myrick813Edit/Delete MessageReply w/QuoteDirect Link to This Post
bump
Ac Fiero
Report this Post08-30-2013 12:56 PM Click Here to See the Profile for Ac FieroSend a Private Message to Ac FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Take the gauge cluster apart and look for breaks or corrosion on the film with the copper strips. Mine had a broken spot that caused my tach to read high
Anson Craig
