  Need Help Mounting 3800 Correctly
Need Help Mounting 3800 Correctly by hinesb1890
Started on: 08-27-2013 11:44 AM
Replies: 4 (386 views)
Last post by: phonedawgz on 08-27-2013 02:20 PM
hinesb1890
Report this Post08-27-2013 11:44 AM Click Here to See the Profile for hinesb1890Click Here to visit hinesb1890's HomePageSend a Private Message to hinesb1890Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have my 3800 and Getrag on the cradle (88') but being my first time I need help with getting it set correctly, so what do I need to line up etc...
aaronkoch
Report this Post08-27-2013 11:53 AM Click Here to See the Profile for aaronkochSend a Private Message to aaronkochEdit/Delete MessageReply w/QuoteDirect Link to This Post
What are you using for mounts? I'm assuming for the Getrag, you used your existing ones, do you have a mount solution for the engine? Are you building your own?
As long as the axles go to the same spot as stock, and the engine is level and straight on the cradle, that's it. Good to go. There is plenty of room around the 3800 in the fiero bay (with the exception of the alternator, requires notching the decklid in its stock location).
darkhorizon
Total ratings: 451
Report this Post08-27-2013 12:13 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
For a manual, I just try to make sure it is level looking. Your stock transmission mounts are going to be your mounting guide, the motor is just along for the ride.
hinesb1890
Report this Post08-27-2013 12:14 PM Click Here to See the Profile for hinesb1890Click Here to visit hinesb1890's HomePageSend a Private Message to hinesb1890Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am using a fieroflyer engine bracket, rodney poly engine mount, and the poly tranny mounts that were on the donor swap... the only difference is the swap is now on an 88' cradle where before it was on an 86'
Total ratings: 290
Report this Post08-27-2013 02:20 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Doggy
