  Not getting spark.
Not getting spark. by bta2011
Started on: 08-25-2013 05:51 PM
Replies: 1 (103 views)
Last post by: Gall757 on 08-25-2013 06:05 PM
bta2011
Report this Post08-25-2013 05:51 PM Click Here to See the Profile for bta2011Send a Private Message to bta2011Edit/Delete MessageReply w/QuoteDirect Link to This Post
86 2m4 and I'm not getting spark. rotor and distributor cap are less than 6 months old. Ignition??
[This message has been edited by bta2011 (edited 08-25-2013).]
Report this Post08-25-2013 06:05 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
When you crank the starter do you see the tachometer move up to 200-400 rpm? If not, then check the ICM, pickup coil and the wires and connectors. If it does, then test the Ignition coil.
[This message has been edited by Gall757 (edited 08-25-2013).]
