  TRUNK SEAL GAP REAR
TRUNK SEAL GAP REAR by fierobug
Started on: 08-25-2013 06:53 AM
Replies: 5 (599 views)
Last post by: fierobug on 08-25-2013 09:16 PM
fierobug
Report this Post08-25-2013 06:53 AM Click Here to See the Profile for fierobugSend a Private Message to fierobugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Will water leak into trunk if seal has 1/4 inch gap on both sides? WHERE DOES the WATER GO? Will get new one when I scrap up the money or birthday?. I don't feel any water on floor of trunk after washing. Thanks for any help.
92wastheyear
Report this Post08-25-2013 12:00 PM Click Here to See the Profile for 92wastheyearSend a Private Message to 92wastheyearEdit/Delete MessageReply w/QuoteDirect Link to This Post
What year and body style?
fierobug
Report this Post08-25-2013 06:01 PM Click Here to See the Profile for fierobugSend a Private Message to fierobugEdit/Delete MessageReply w/QuoteDirect Link to This Post
It is a 1987 gt. Seal is shrunk on sides - leaving a gap.
seajai
Total ratings: 51
Report this Post08-25-2013 07:55 PM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
The GT uses a plastic "D" filler piece on each side to square off the trunk opening compared to the notchie. The trunk seal attaches to them, leaving a gap between the seal and the bodywork. This is normal. The water hits the top of the filler and just runs out.
92wastheyear
Report this Post08-25-2013 09:13 PM Click Here to See the Profile for 92wastheyearSend a Private Message to 92wastheyearEdit/Delete MessageReply w/QuoteDirect Link to This Post
I too have an 87 GT....when I had a leak into the trunk, it was from water dripping down thru the bolts that hold the wing on. I ended up caulking that area.
fierobug
Report this Post08-25-2013 09:16 PM Click Here to See the Profile for fierobugSend a Private Message to fierobugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you seajai for the information. The seal is split towards the engine, but I can order one from infinitewill when I get the cash. Also thank you 92wastheyear, I'll caulk the bolts from the wing before it starts leaking.
[This message has been edited by fierobug (edited 08-25-2013).]
