  W toant install a/c
W toant install a/c by f85gtron
Started on: 08-23-2013 01:16 PM
Replies: 6 (198 views)
Last post by: f85gtron on 08-24-2013 06:06 AM
f85gtron
Report this Post08-23-2013 01:16 PM Click Here to See the Profile for f85gtronSend a Private Message to f85gtronEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi all...
85 gt notchie
No factory a/c.
I want to install a/c. I searched posts and only found this subject in archived form, one from 2001 and one from 2008. In both, no one clearly defined what systems work best, what doner cars are suitable, and so on....
It's next to impossible to pull from a doner fiero nowdays, so what about s10 and firebirds? Also, what about the 12v commpressers that are out now for hybrids?
How many btu's for the fiero?
Btw, neighsayers, I will not give up....I'm in georgia...we need it in the winter here too!
Ron
Report this Post08-23-2013 01:23 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
fierosound
Total ratings: 286
Report this Post08-23-2013 01:24 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Though some of the mechanicals may work, you're still going to need the HVAC box/ducting and controls and likely the A/C lines under the car from a Fiero.
I couldn't get a new evaporator for my Indy - had to get used. I've replaced virtually everything (new condenser this spring) and after 6 years still don't have it working right.
Works great when freshly recharged, but pressure disappears in a week with no visible leaks under a black light.
[This message has been edited by fierosound (edited 08-23-2013).]
Stubby79
Total ratings: 58
Report this Post08-23-2013 02:12 PM Click Here to See the Profile for Stubby79Send a Private Message to Stubby79Edit/Delete MessageReply w/QuoteDirect Link to This Post
No factory A/C on a GT? Is that normal for an '85?
f85gtron
Report this Post08-23-2013 09:24 PM Click Here to See the Profile for f85gtronSend a Private Message to f85gtronEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by 2.5:
2 more threads
https://www.fiero.nl/forum/A...110502-2-107662.html
https://www.fiero.nl/forum/A...090219-2-085157.html
thanks for the threads.
The first one didn't get any further than the ones from before.
The second....well, uh, that was a little tmi....and, with all the theoretical this and that.....they STILL didn't answer the question with application...just theory.
I think i'm just going to have to do it and prove theory wronge! If it works, I'll do a write up, if it fails, you'll never know
Ron
f85gtron
Report this Post08-23-2013 09:26 PM Click Here to See the Profile for f85gtronSend a Private Message to f85gtronEdit/Delete MessageReply w/QuoteDirect Link to This Post
f85gtron
Member since Jul 2013
If it's not, I WANT MY $350 BACK!
f85gtron
Report this Post08-24-2013 06:06 AM Click Here to See the Profile for f85gtronSend a Private Message to f85gtronEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can't remember where I found this pic, but this would be perfect for my application! I figure I could make one by making a crude blank and having one vaccume formed at a sign shop... Then I stay true to the "purists' code" (bolt on/off) and don't have to screw around with air box changing/breaking old plastic thingies.
Our KW day cabs run 1.5 ton capacity systems and the can is approximately the same volume as the fiero, so, how does that translate into btu's? That's just what's stamped on the expansion valve...it may not actually have that capacity...
Conventional route: which compressor should be used with the 85 2.8?
[This message has been edited by f85gtron (edited 08-24-2013).]
