First |
Page 1 of 1 |
Last |
Goto |
C-203 connector VSS high VSS low? by trotterlg
Started on | : 08-22-2013 02:17 PM |
Replies | : 1 (337 views) |
Last post by | : Bloozberry on 08-22-2013 03:22 PM |
Aug 22nd, 2013
trotterlg Member Posts: 1378 From: WA Registered: Aug 2011
Where do these lines go to? Got everyting wired in except these two. I see the VSS spedo to engine ground. Larry
02:17 PM
Bloozberry Member Posts: 7760 From: Registered: Jan 2009
The purple wire runs from the VSS sender pin B, to C203 pin A, then to the instrument panel connector C1 pin R.
The yellow wire runs from the VSS sender pin A, to C203 pin D, then to the instrument panel connector C1 pin S.
Instrument panel connector C1 is the vertical one just above your left knee when sitting in the driver's seat.
03:22 PM
First |
Page 1 of 1 |
Last |
Goto |
