  Manual transmission gear oil temperature
Manual transmission gear oil temperature by Joseph Upson
Started on: 08-21-2013 09:45 AM
Replies: 17 (4064 views)
Last post by: hobbywrench on 08-24-2013 10:59 AM
Joseph Upson
Total ratings: 88
Report this Post08-21-2013 09:45 AM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm curious to know if anyone has any idea of what temperature their manual transmission gear oil reaches. While on the dyno a couple days ago, my charge pipe blew off and while reconnecting it I bumped the final drive area of the transmission and noted it was very hot leading me to suspect manual transmissions behind loads in excess of what they were designed for might benefit from an oil cooler and electric pump looped into the drain and fill holes.
If the oil temps are reaching 200+ deg I think it would be worth it as the F40 has been known to show more shift resistance when cold even with the engine off to suggest possible tolerance variance with temp change. Perhaps using synchromesh in my first tranny was part of the failure equation in the same manner that too thin or too hot an oil in a hard run motor can compromise durability.
Now I wonder if running the tranny at a lower oil level than initially prescribed to combat shift resistance problems is a good idea as a result of the reduced heat capacity that will result.
Justinbart
Total ratings: 119
Report this Post08-21-2013 09:53 AM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nope
Turbo 3800 E85 F23 5spd spec5
11.17@132.6
Report this Post08-21-2013 10:14 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
The heat they do have would probably be from the engine being bolted to them and exhaust nearby. Does the tranny oil even get pumped? I dont think there is much of a way to cool it?
Running the fluid level low could probably never be advised for any reason.
[This message has been edited by 2.5 (edited 08-21-2013).]
Joseph Upson
Total ratings: 88
Report this Post08-21-2013 10:16 AM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Justinbart:
Nope
It may be something to consider. I can't imagine gear oil remaining near normal operating temps being subjected to loads far in excess of what the motors they were attached to from the factory generated, especially in the absence of any proof to the contrary.
Some of the WRX and Saab owners have switched to more shock resistant oil for hard driven manual cars that also see more power output than stock and some also change the gear oil at intervals far more frequent than factory recommendations.
Joseph Upson
Total ratings: 88
Report this Post08-21-2013 10:19 AM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Joseph Upson
Member since Jan 2002
I was first told by a Saab tranny builder that lowering the oil level was the fix for the F40 cold shift complaints followed later by some one stating that GM mandated it, but that's for a stock application. I run the full dose.
What I felt was definitely not engine or exhaust heat derived.
[This message has been edited by Joseph Upson (edited 08-21-2013).]
jaskispyder
Total ratings: 205
Report this Post08-21-2013 11:02 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
get an ir temp gun and see what it says. Or get probe and put it into the oil after a run to see what the temps are.
Justinbart
Total ratings: 119
Report this Post08-21-2013 11:43 AM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll shoot the temp of the case next time i'm out.
11.17@132.6
aaronkoch
Report this Post08-21-2013 12:17 PM Click Here to See the Profile for aaronkochSend a Private Message to aaronkochEdit/Delete MessageReply w/QuoteDirect Link to This Post
Anecdotal info:
I used to run a loose-bearing Muncie 4 speed behind my 3800, and when drag racing it it would get hot enough to shoot oil out the vent. The Isuzu behind it now is much tighter and newer, and barely gets warm.
I suspect that the slight tolerance and angle change that results from bearing wear in the trans (especially in the differential bearings) leads to a significant increase in friction and heat.
From what I understand, oil is pulled thru the shafts when the gearsets are spinning; they act like a centrifugal pump.
Blacktree
Total ratings: 350
Report this Post08-21-2013 12:22 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Keep in mind that the transmission (even a manual transmission) absorbs some of the engine power, due to frictional losses. That absorbed energy is mostly turned into heat. The more powerful the engine, the more heat is dumped into the gearbox.
The big question is whether or not not you can get to a point where the gearbox absorbs enough heat to cause negative effects. I think the only way to determine that is through experimentation.
Report this Post08-21-2013 02:16 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
I looked a little online, big trucks that tow, and diesels do put coolers on their manual trannies sometimes.
http://www.thoroughbreddies...nsmission-cooler.htm
Interesting. Hard to shift when its cold, wouldnt the answer be (example) instead of say 5w30 use 0w30?
Joseph Upson
Total ratings: 88
Report this Post08-21-2013 04:03 PM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
You would think, but apparently it's not that simple. The problem was first complained about in stock G6 cars where some owners were practically locked out of 1st and 2nd gear except for starting the car with the gear engaged until it warmed up a little. Even with the motor off, on a cold day I can feel considerable stiffness in the gear shifter although you would think much of the oil is in the bottom of the transmission away from most of the gears.
I did read mention of high gear tooth temps as one source of considerable heat not unlike the engine oil coming off the bearings at a higher temp than what's in the pan. I've also seen a number of late model rear end failures mainly involving SUVs which I thought in the past was a rare incident. Can't attribute it to poor install at the factory because when they're wrong they whine from the start. Some production cars have temp sensors in the differential.
Total ratings: 463
Report this Post08-21-2013 09:57 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
... Some production cars have temp sensors in the differential.
A lot of "track ready" cars like the new Z28 and others also have differential oil coolers. Can't say I've heard of a manual tranny cooler, but that doesn't mean they're not out there.
It occurs to me that the 90 degree angle between the ring and pinion in a conventional rear end may generate a lot more heat than transmission gears.
dematrix86gt
Report this Post08-22-2013 12:31 AM Click Here to See the Profile for dematrix86gtSend a Private Message to dematrix86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Weve used Holley Black fuel pumps to pump oil out of the trans to a cooler and back into the trans. the main line has to have a orfice in it to slow the oil down long enough to stay in the cooler to cool the temp down. Just use the Lower drain plug as a pickup and the side check plug as the return. Holley black pumps push oil good so i dont know about any other pumps that would.
Joseph Upson
Total ratings: 88
Report this Post08-22-2013 04:36 AM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's exactly the kind of arrangement I was imagining as I already have a Holley Black fuel pump in place from temporary use with my turbo oil return, used until it was clear the oil return was sufficient without it. You just have to remember to remove the stainless mesh screen so that there's no problem with oil pickup flow during really cold weather when the oil is thickest.
It just seems to me that if by chance oil temps are reaching and exceeding 200 deg at any time, a cooler might benefit structural integrity by reducing tolerance changes due to heat in applications that far exceed component rated limits, by nearly double in some cases.
Report this Post08-22-2013 08:57 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
One could also run a larger capacity of oil, probably would need to anyway for how much the cooler holds, but a larger reservoir could help with cooling.
Justinbart
Total ratings: 119
Report this Post08-22-2013 04:27 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
I shot the case with an IR gun. 83* outside about 30 miles a few runs over 100mph. The diff and the top of the trans case both read 160*f. Oil pan reads 211*. It was too hot to touch for more than a split second.
11.17@132.6
Joseph Upson
Total ratings: 88
Report this Post08-22-2013 04:52 PM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
In that case it's hotter than that coming off the gears and inside the case. I imagine putting synchromesh in the first F40 I installed instead of the high dollar full synthetic recommended for it probably didn't help my situation and may have contributed to the eventual failure.
hobbywrench
Report this Post08-24-2013 10:59 AM Click Here to See the Profile for hobbywrenchSend a Private Message to hobbywrenchEdit/Delete MessageReply w/QuoteDirect Link to This Post
A candy thermometer might work lowered into the oil fill hole. I use K thermocouple probes on my rider lawnmower. The thermometers are $30 and up on line and some are junk, but others are very good. The K thermocouple is extremerly accurate and widely used for exhaust gas temp , cyl head temp , lab work etc. Some VOMs include the function. I think I saw a Harbor Freight unit with it cheap. I made an oil sump probe from brake line and K termocouple wire. Not too hard. The guns probably are picking up case temps when aimed? For those interested the AC rider I have runs sump temps of 290-300F doing hard work. I put on a fan-cooled oil cooler.
