  Is the hose from the radiator to the antifreeze tank anything special on 1984 Fiero?
Is the hose from the radiator to the antifreeze tank anything special on 1984 Fiero? by Fiero.1984
Started on: 08-20-2013 02:21 PM
Replies: 8 (213 views)
Last post by: Fiero.1984 on 08-21-2013 10:56 PM
Fiero.1984
Report this Post08-20-2013 02:21 PM Click Here to See the Profile for Fiero.1984Send a Private Message to Fiero.1984Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have 1984 Fiero SE with 2.5 motor. I am replacing the antifreeze tank. It has a hose from the antifreeze tank to the radiator that looks unusual to me. It seems to be extremely flexible. It is something special or can you just buy one at a parts store?
Thanks.
steve308
Total ratings: 58
Report this Post08-20-2013 02:57 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Any parts store standard rubber heater hose of the same size will work.
[This message has been edited by steve308 (edited 08-20-2013).]
Fiero.1984
Report this Post08-20-2013 03:06 PM Click Here to See the Profile for Fiero.1984Send a Private Message to Fiero.1984Edit/Delete MessageReply w/QuoteDirect Link to This Post
It does not look like any heater hose that I have ever seen. It is thin and flexible. All of the heater hoses that I have ever seen are much thicker and more rigid.
Report this Post08-20-2013 05:29 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don't over-tight that hose. GM used metal "spring type" fuel clamp or nylon clamp because that won't crush the soft rubber.
Fill after a flush then do not use 50/50 mix.
See my Cave, Coolant Fill
steve308
Total ratings: 58
Report this Post08-20-2013 05:44 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
It's a hose.
trotterlg
Report this Post08-20-2013 07:46 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just any rubber hose, it does not carry any pressure. Larry
RWDPLZ
Total ratings: 305
Report this Post08-20-2013 09:17 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any heater hose, it's not under high pressure or anything, 16psi max.
trotterlg
Report this Post08-21-2013 12:37 AM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not near 16 psi, near less than one. Larry
Fiero.1984
Report this Post08-21-2013 10:56 PM Click Here to See the Profile for Fiero.1984Send a Private Message to Fiero.1984Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the info. Took my old one to auto store and bought one that similar to my old one.
