| | | quote | Originally posted by Sigler85GT:
First off, not looking for any 3800 is way better talk. I alreay have that covered. Or the aluminum heads are better than the iron. I am not arguing this but i like the way our cars look from the factory. For the most part. I understand the mechanical parts that are needed to mate the two together.
what hp can the stock bottom end take on the 3400? I know the compression ratio is lowered if using the iron heads and stock 3400 pistons but what is the ratio exactly?
If you were to boost the iron heads would the intake restriction still be as big of a problem as it is NA? And if you were to remove the fin from the heads does that matter with the boost being added?
Would the 7730 icm be a wise choice to run the engine with and will it support the 3400 stock coils? |
The bottom end is pretty stout on the 3x00.
cross bolted mains
same "981" casting found in 3.1/3.4/3x00s.
powder forged rods
pistons will become the weak point with power adder
turbo 3400removing the vane will hurt flow #s even with boost. OTOH, curtis(turboz24) built a 3.2 a number of years ago with iron heads, vane was completely removed. Turbocharged, the 3.2 put down 475whp, but that engine was built to rev to 8000 rpms(iirc).
