  Rear cradle bushing plate needed??
Rear cradle bushing plate needed?? by 85GT_3800SC
Started on: 08-17-2013 01:57 PM
Replies: 3 (233 views)
Last post by: 85GT_3800SC on 08-17-2013 04:15 PM
85GT_3800SC
Report this Post08-17-2013 01:57 PM Click Here to See the Profile for 85GT_3800SCSend a Private Message to 85GT_3800SCEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was working on getting my spare cradle ready for my L67 swap and came across these thin plates tacked onto the top of the bushing mounting surface.
The oem bushings have a steel plate that sits on this plate,but I will be installing poly bushings that do not have such a plate on them and I am wondering if theses plates are even needed when using poly bushings.Once welded on, these plates form a rust trap so I would rather not use them.Thanks in advance for any opinions.
Al
trotterlg
Report this Post08-17-2013 02:49 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have two cradels sitting here and both have thos on top. Mine are welded on very securely, so I think you will need them. Larry
Report this Post08-17-2013 03:58 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
If yothe are worriedthe about rust, prime and paint both the plate and the cradle and use some sealant to stick them together and seal the mating surfaces from water.
85GT_3800SC
Report this Post08-17-2013 04:15 PM Click Here to See the Profile for 85GT_3800SCSend a Private Message to 85GT_3800SCEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi Guys and thanks for the replies. I didn't think about using an adhesive.That is a great idea. I bet POR 15 would fit the bill to coat and secure the plate/cradle. Its tough as nails and an excellent rust sealer!
Thanks again.
Al
