  How low is my Fiero??? (Pictures)
How low is my Fiero??? (Pictures) by Str8lineJKing
Started on: 08-15-2013 03:48 PM
Replies: 16 (627 views)
Last post by: crashyoung on 08-17-2013 07:07 PM
Str8lineJKing
Report this Post08-15-2013 03:48 PM Click Here to See the Profile for Str8lineJKingSend a Private Message to Str8lineJKingEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello all. When i bought the car i was told it was lowered but i have no idea how much it was lowered. It does not appear to have cut springs as it looks like an actual lowering kit. I love the height of the rear of the car. But as you can see in the pictures, the front is about an inch or two higher than the rear. I was just curious to see what other peoples lowered fieros looked like and how much it was lowered. I have tried finding the stock ride height to no avail.
I have not taken measurements yet. But i will just after i post this new topic to compare actual ride heights.
92wastheyear
Report this Post08-15-2013 03:55 PM Click Here to See the Profile for 92wastheyearSend a Private Message to 92wastheyearEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks completely stock height to me....just like mine
Str8lineJKing
Report this Post08-15-2013 03:58 PM Click Here to See the Profile for Str8lineJKingSend a Private Message to Str8lineJKingEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok so i got some actual measurments.
From the ground the the top of the wheel arch
Front 27.8 inches
Rear 26.1 inches
I would measure the front at the crossmember but i cant get under it far enough to measure accurately.
Steven Snyder
Total ratings: 106
Report this Post08-15-2013 04:01 PM Click Here to See the Profile for Steven SnyderClick Here to visit Steven Snyder's HomePageSend a Private Message to Steven SnyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Front 27.8 inches
Rear 26.1 inches
Measure it from the center of the wheel to the top of the wheel arch, otherwise you'll only be able to compare to other people with exactly the same tire size.
Str8lineJKing
Report this Post08-15-2013 04:05 PM Click Here to See the Profile for Str8lineJKingSend a Private Message to Str8lineJKingEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks good idea. Even though i have the stock 205 on front and 215 rear i think.
But the measurements are 15.6 ish inches on front and just under 14 on rear.
Report this Post08-15-2013 04:12 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks stock to me....
Str8lineJKing
Report this Post08-15-2013 04:14 PM Click Here to See the Profile for Str8lineJKingSend a Private Message to Str8lineJKingEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, since it looks stock. Does anyone know what the actual number for the stock ride hight is? Like someone with access to Alldata or ShopKey
Damorgan
Report this Post08-15-2013 04:23 PM Click Here to See the Profile for DamorganSend a Private Message to DamorganEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is my lowered Fiero on 17 inch wheels.....
Neils88
Total ratings: 56
Report this Post08-15-2013 07:24 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Paint needs work...but love those rims!! Do you have a profile view? How much was this lowered?
Bloozberry
Total ratings: 311
Report this Post08-15-2013 08:24 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
The service manual states that regardless which stock wheel and tire combo you have, the distance from the ground to the underside of the rocker panel should be as follows:
193 mm (7.6") high at a location 500 mm (19.7") behind the centerline of the front wheel; and
186 mm (7.3") high at a location 573 mm (22.5") ahead of the centerline of the rear wheel.
Boostdreamer
Total ratings: 98
Report this Post08-15-2013 10:19 PM Click Here to See the Profile for BoostdreamerSend a Private Message to BoostdreamerEdit/Delete MessageReply w/QuoteDirect Link to This Post
...after the zombie apocalypse.
Jonathan
My '85 L67 Build Thread
[This message has been edited by Boostdreamer (edited 08-15-2013).]
Damorgan
Report this Post08-15-2013 10:34 PM Click Here to See the Profile for DamorganSend a Private Message to DamorganEdit/Delete MessageReply w/QuoteDirect Link to This Post
lol The Fiero wont let you down..that often lol
BillS
Report this Post08-16-2013 11:23 AM Click Here to See the Profile for BillSSend a Private Message to BillSEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can also measure to the roof - 48" IIRC. Need a long level though.
Damorgan
Report this Post08-17-2013 11:24 AM Click Here to See the Profile for DamorganSend a Private Message to DamorganEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry Neil just now saw that you commented, Ill be taking pictures of it to give you a better idea and tbh I have no idea what its lowered to but Ill try and get a measurement for you
rourke_87_T-Top
Report this Post08-17-2013 04:44 PM Click Here to See the Profile for rourke_87_T-TopSend a Private Message to rourke_87_T-TopEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the sparks don't fly you're too F-ing high !
30+mpg
Total ratings: 97
Report this Post08-17-2013 06:47 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
crashyoung
Report this Post08-17-2013 07:07 PM Click Here to See the Profile for crashyoungSend a Private Message to crashyoungEdit/Delete MessageReply w/QuoteDirect Link to This Post
Where is the pop/beer can for perspective??!!??
