  Notchie smooth molding
Notchie smooth molding by Phirewire
Started on: 08-08-2013 12:47 AM
Replies: 4 (373 views)
Last post by: rcp builders on 08-09-2013 01:56 PM
Phirewire
Report this Post08-08-2013 12:47 AM Click Here to See the Profile for PhirewireSend a Private Message to PhirewireEdit/Delete MessageReply w/QuoteDirect Link to This Post
I know the 87-88 notch fieros has smooth molding, at least on the new body style. Now I wanna keep the Aero front end, so can I use a smooth from an 87-88 and then put on a GT front nose and use smooth molding all around? or will this not work?
Report this Post08-08-2013 07:34 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Use an 86-88 nose from a GT, the rear fascia from the same. If you start with an aero notchie, change the ribbed side moldings to smooth and you will have a round molding aero notchie with the proper ground effects to match the front and rear GT fascias.
Report this Post08-08-2013 07:44 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you start with a ribbed aero fascia, you can cut the ribbed portion off and mount the smooth molding over the hole.
Tha Driver
Total ratings: 204
Report this Post08-08-2013 07:42 PM Click Here to See the Profile for Tha DriverClick Here to visit Tha Driver's HomePageSend a Private Message to Tha DriverEdit/Delete MessageReply w/QuoteDirect Link to This Post
What year is your car? The later aero noses have bolt-on molding ends (the bullets) & you can swap out for the smooth ones if yours are ribbed. As mentioned, you have to change out the rear bumper with the smooth molding as it's molded in. The sides will all swap out. You have to pull the door skins to swap out the little moldings behind the door handle - they bolt on from the back.
~ Paul
aka "Tha Driver"
Custom Fiberglass Parts
rcp builders
Report this Post08-09-2013 01:56 PM Click Here to See the Profile for rcp buildersSend a Private Message to rcp buildersEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fill the ribs in with this stuff and then repaint. Ray
http://www.evercoat.com/productDetail.aspx?pID=36
