  Gen 2 Headlights - Why did I wait so long?
Gen 2 Headlights - Why did I wait so long? by NetCam
Started on: 08-07-2013 09:30 PM
Replies: 15 (665 views)
Last post by: NetCam on 08-11-2013 10:07 AM
NetCam
Report this Post08-07-2013 09:30 PM Click Here to See the Profile for NetCamClick Here to visit NetCam's HomePageSend a Private Message to NetCamEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had heard the Gen 2 motors were quieter than the Gen 1, but I had no idea! I wish I had done this a long time ago.... To anybody considering this swap, it's worth the effort!
Gen 1
Put the motors in the way I bought them, that didn't go so well!
After replacing the bump stops, worked like a charm!
Tomorrow I do the passenger side
[This message has been edited by NetCam (edited 08-11-2013).]
rbell2915
Report this Post08-08-2013 12:17 AM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
I totally agree! When I put the passenger motor in, I was blown away at how much quieter it is. I'm waiting for my driver's side motor to come in the mail. Although, I do have this problem where I have to turn on the lights (the Gen II HL won't flip up) (my Gen I is totally useless) then turn them off, and then turn them back on again and then the headlight rises. Do you have any ideas on why this would be happening?
NetCam
Report this Post08-08-2013 08:19 AM Click Here to See the Profile for NetCamClick Here to visit NetCam's HomePageSend a Private Message to NetCamEdit/Delete MessageReply w/QuoteDirect Link to This Post
That sounds a bit odd, but my first guess would be the headlight switch itself, and if not there I would check the isolation relay.
Fiero84Freak
Report this Post08-08-2013 12:37 PM Click Here to See the Profile for Fiero84FreakSend a Private Message to Fiero84FreakEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have Gen 2 headlights on my '86 GT and it's one of the better upgrades on my car. They're super quiet and work great. With the past Fieros I had that were 84-86 I always had Gen 1 issues so having Gen 2 setup is great.
benoitmalenfant
Report this Post08-08-2013 03:54 PM Click Here to See the Profile for benoitmalenfantSend a Private Message to benoitmalenfantEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ditto what NetCam said.
I had a similar issue on my 87 (well, mine would not shutoff on first try, I'd have to do it 2-3 times or press hard on the off button and keep it pressed until the lights completely down), turned out the switch itself was the issue, one of the metal prongs that gets tripped by the switch would not fully touch the metal base plate.
I don't have the pictures handy but I took pictures of what I did to fix the issue (some cleaning on the contact area of the prongs and some dielectric grease). I'll post them here when I get home tonight.
Ben
87 GT / 88 GT
84 Indy #1863
Shonyman32
Report this Post08-08-2013 05:37 PM Click Here to See the Profile for Shonyman32Send a Private Message to Shonyman32Edit/Delete MessageReply w/QuoteDirect Link to This Post
Did you buy the motors or rebuild some?
rbell2915
Report this Post08-08-2013 08:31 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, thank you both! It seems that the motor torque themselves down a little too tight, requiring two pushes to get them to work. After dinner, it'll be worth a look.
I bought one off eBay, and put new bushings in it. The other one John316 gave to me and it worked great.
NetCam
Report this Post08-08-2013 10:50 PM Click Here to See the Profile for NetCamClick Here to visit NetCam's HomePageSend a Private Message to NetCamEdit/Delete MessageReply w/QuoteDirect Link to This Post
Passenger side is done.... It was quite a challenge, as I'm sure anybody who's done the rebuild before would know. To get the gear off on the passenger side you have to remove the screws that hold down the top part of the motor and lift the housing. In my case, both screws snapped off as soon as I tried to turn them. I managed to drill both of them out and replace with a nut, bolt and lock washer. This was no fun! I had to remove the top section completely to do the drilling, which entails the brushes coming out of their little homes and springs randomly flying around my dining room (It's OK, I live alone so the dining room table doubles as my workbench ). After a few hours of playing around and using twist ties to hold the springs back while I reassembled the motor, all is good in my Fiero world!
It was complete daylight when I started, finished the job wearing a head torch for light. The neighbours probably thought I had started some sort of mining operation.......
rbell2915
Report this Post08-09-2013 03:06 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
Mine are still having problems. Maybe it's the module?
Sonny Burnett 21
Report this Post08-09-2013 09:28 PM Click Here to See the Profile for Sonny Burnett 21Send a Private Message to Sonny Burnett 21Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm going threw that same thing with my fiero headlight swap now my module went out and I bought a flawed wire harness now I have to change everything. Double check your harness and change your module. If your motor continue to go faster you might have to change the motors. Because the motor might slowly go out
rbell2915
Report this Post08-09-2013 09:44 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
My dad and I swapped out the module from his Firebird and it works way better now. There still is lag in the right motor though. But when the hood is up and the lights are turned on they both go up at the same time. Maybe there's a difference in amperage because the wire is so much longer. So we're going to get thicker wire and see what happens when we change it.
Sonny Burnett 21
Report this Post08-10-2013 09:52 AM Click Here to See the Profile for Sonny Burnett 21Send a Private Message to Sonny Burnett 21Edit/Delete MessageReply w/QuoteDirect Link to This Post
Mines used to do that too. Until I broke my motor down to see why it was doing that. And come to find out that my bushings were sand (wore out) witch was keeping them from coming up at the same time
benoitmalenfant
Report this Post08-10-2013 11:12 AM Click Here to See the Profile for benoitmalenfantSend a Private Message to benoitmalenfantEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wouldn't worry about the slight difference in speed. It might very well be related to the length of the wire but you might spend a lot of time troubleshooting something that is not much of a problem.
I'm glad you found the module was at fault. In my case, the switch was the issue.
I said I was going to post pictures, so here comes:
Unplug the switch:
Open the switch's case:
Remove the On/Off rockers:
Once the rocker removed, you'll see three prongs.
When the lights are down, only prong #3 makes contact with the base plate
When the marker/tail lights only are on, only prong #2 makes contact with the base plate
When all lights are on, only prong #1 and #2 make contact with the base plate.
In my case, there was a bit of gunk build-up on the base plate in the area where the prongs make contact and prong #3 would not make full contact unless I pressed hard on the switch. I cleaned up the old dielectric grease and cleaned-up the gunk build-up from the base plate as much as I could with a small flat screwdriver some electric contact cleaner and a small rag. Once this was done, my lights would close normally.
[This message has been edited by benoitmalenfant (edited 08-10-2013).]
NetCam
Report this Post08-10-2013 05:59 PM Click Here to See the Profile for NetCamClick Here to visit NetCam's HomePageSend a Private Message to NetCamEdit/Delete MessageReply w/QuoteDirect Link to This Post
^ Great write-up, bet quite a few will find that one helpful!
rbell2915
Report this Post08-11-2013 12:00 AM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
My father and I found a fix for the headlight lag. What we did was we taped some pieces of wood onto the assembly where the arm rests on, so then it would be farther up, thus going up at the same time. It's not a permanent fix. We did find that the middle bolt holding the motor in was close to the top of the wood, so tomorrow we're going to Ace to get a longer bolt and some nuts to screw on so then it's more permanent. And as you can tell, I think the module is failing at a more rapid rate.
NetCam
Report this Post08-11-2013 10:07 AM Click Here to See the Profile for NetCamClick Here to visit NetCam's HomePageSend a Private Message to NetCamEdit/Delete MessageReply w/QuoteDirect Link to This Post
There isn't any chance that you have the middle bolt brushing against the actuator arm is there? Because the Gen 2 motors are smaller I had to cut about 1/4" off 2 of the 3 bolts so they didn't stick out. The only one I left alone was the one at the bottom of the motor because it's hidden under the bucket and won't get in the way of anything.
Here's the bolts and a couple of the bits I cut off with a Dremel
