  Fuel hose sizes
Fuel hose sizes by thebigarniedog
Started on: 08-04-2013 04:33 PM
Replies: 3 (713 views)
Last post by: Joseph Upson on 08-05-2013 09:13 AM
thebigarniedog
Report this Post08-04-2013 04:33 PM Click Here to See the Profile for thebigarniedogSend a Private Message to thebigarniedogEdit/Delete MessageReply w/QuoteDirect Link to This Post
What are the sizes for the rubber fuel hoses that come off of the 3 metal lines from the tank? Thanks
thebigarniedog
Report this Post08-04-2013 08:39 PM Click Here to See the Profile for thebigarniedogSend a Private Message to thebigarniedogEdit/Delete MessageReply w/QuoteDirect Link to This Post
anyone have an answer?
Fiero_Guy
Report this Post08-05-2013 08:42 AM Click Here to See the Profile for Fiero_GuySend a Private Message to Fiero_GuyEdit/Delete MessageReply w/QuoteDirect Link to This Post
3/8" and 5/16" if I recall correctly
Joseph Upson
Total ratings: 88
Report this Post08-05-2013 09:13 AM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do some research on your choice of replacement, the readily available fuel injection hose most likely to be presented is not as good as the OE which if you look closely you'll note it appears to have a hard plastic inner liner pretty much like the A/C flex hose. The typical hose which looks like regular conventional fuel hose except for the high pressure rating does not weather well. I read over a thread a few weeks ago after looking up the specs on some extra FI hose I had laying around where after a few years use the hose was cracking on the outside as if it were part of a very old tire.
You need to use at least SAE30R9 hose.
http://www.gates.com/common...ure/TechTipsForm.pdf
[This message has been edited by Joseph Upson (edited 08-05-2013).]
