  turbo 3800
turbo 3800 by yellow fever
Started on: 08-03-2013 09:07 PM
Replies: 6 (463 views)
Last post by: darkhorizon on 08-05-2013 08:20 PM
yellow fever
Report this Post08-03-2013 09:07 PM Click Here to See the Profile for yellow feverSend a Private Message to yellow feverEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi guys. On a turbo 3800 what should I set my command afr in pe too.
Hudini
Total ratings: 165
Report this Post08-04-2013 12:02 AM Click Here to See the Profile for HudiniSend a Private Message to HudiniEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are you going to dyno tune the car or just seat-o-the-pants? Start in the 11.0-11.5 range then work up. For a street tune go rich and stay away from KR. A racing tune will be in the 12's to low 13s depending on mods and how your O2 sensor is calibrated. It all depends on your engine and your setup. Don't mess up your engine on free advice though. Test carefully.
yellow fever
Report this Post08-04-2013 09:06 AM Click Here to See the Profile for yellow feverSend a Private Message to yellow feverEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks hudini. I have it set at 11.3 now. It seems like it is loading up. You let up on the gas a little and it will take off. Going down to the tuning shop on monday to talk to him about pricing. We can't seem to fix or find the issue with this full throttle bog.
yellow fever
Report this Post08-04-2013 02:30 PM Click Here to See the Profile for yellow feverSend a Private Message to yellow feverEdit/Delete MessageReply w/QuoteDirect Link to This Post
yellow fever
Member since May 2002
nosrac
Total ratings: 50
Report this Post08-04-2013 02:59 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Might want to ping DH for tuning help.
yellow fever
Report this Post08-05-2013 05:29 PM Click Here to See the Profile for yellow feverSend a Private Message to yellow feverEdit/Delete MessageReply w/QuoteDirect Link to This Post
I will have to hit up DH.
[This message has been edited by yellow fever (edited 08-05-2013).]
darkhorizon
Total ratings: 451
Report this Post08-05-2013 08:20 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
11.3 is a good target ACTUAL AF, but you would want to verify that your actual AF is the same via a wideband.
