  3800 turbo vacuum line help.
3800 turbo vacuum line help. by yellow fever
Started on: 07-27-2013 01:40 PM
Replies: 1 (243 views)
Last post by: 1fast2m4 on 07-27-2013 06:41 PM
yellow fever
Report this Post07-27-2013 01:40 PM Click Here to See the Profile for yellow feverSend a Private Message to yellow feverEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi guys. I have a turbo 3800. I This is the second year I have had a turbo on my 3800. I am using a l26 intake. Where are you guys running vacuum off of this for the map sensor and fuel pressure regulator and blow off vavle. I had mine in the same place it was when it was SC on the lower intake and it was full of oil. I moved it up to the upper intake to the vacuum spot on the front of it and its full of oil again.That cant possibly be normal can it. Im pretty tired of this car, so if anyone can give me some info or ideas it would be awesome. I'm so sick of this thing i'm getting ready to either sell it or part it out.Thanks for any ideas
1fast2m4
Report this Post07-27-2013 06:41 PM Click Here to See the Profile for 1fast2m4Send a Private Message to 1fast2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
What are you using for PCV? maybe leave the Vac lines alone a install a PCV catch can
Everyting runs good, just the lines had oil in them?
1986 SE 3800SC/4t65eHD (12.871@104.96) I'll Sell it if you like
1985 GT 3800SC (swap in progress)
