  88 Sway Bar Refresh > suggestions / tips?
88 Sway Bar Refresh > suggestions / tips? by sricka01
Started on: 07-25-2013 02:35 AM
Replies: 1 (237 views)
Last post by: 2.5 on 07-25-2013 10:28 AM
sricka01
Report this Post07-25-2013 02:35 AM Click Here to See the Profile for sricka01Send a Private Message to sricka01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Both my front and rear sway bar bushings are rotted. I quickly learned that not all sites have these in stock. I was so confused because Autozone kept referencing 22MM bushings for 88, when 22 seems to only apply to 84-87. So do you all think the following parts will fit the 88 GT assembly okay? I hope I have ordered the right parts. How hard is it to replace the end link bushings or the mounting bracket bushings? Should I replace either one first? I have spare poly bushings to do the front or back, so that's why I only ordered one set. I think I might have got a good deal on the KYB shocks too.
Energy Suspension 9.11104 Formula 5 Prelube (8 oz. tub)
http://www.amazon.com/dp/B0...309540_26725410_item $16.94
Energy Suspension 9.8117R End Link Set With Hardware
http://www.amazon.com/dp/B0...309540_26725410_item $21.67
Energy Suspension 9.5130R 28mm Stabilizer Bar Bushing Set
http://www.amazon.com/dp/B0...309540_26725410_item $12.71
Energy Suspension 9.5127R 23mm Stabilizer Bushing (Rear mount?)
http://www.amazon.com/dp/B0...309540_26725410_item $18.28
KYB Shocks
http://www.amazon.com/dp/B0...309540_26725410_item $23.21ea
Report this Post07-25-2013 10:28 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
The mount bushings are not hard, I replaced mine on a Formula with black energysusp poly. However my end links are stock, though they look like a whitish colored poly.
For the mounts I just got the bushing that was the right diameter inside for the bar and mounted new bracket and bushing, From most parts stores, the bracket is a brass color but no one can see it. looks like one of those last 2 links you provided, just measure your bar.
