  Clutch pedal
Clutch pedal by stevep914
Started on: 07-21-2013 06:56 PM
Replies: 4 (162 views)
Last post by: stevep914 on 07-22-2013 08:14 PM
stevep914
Report this Post07-21-2013 06:56 PM Click Here to See the Profile for stevep914Send a Private Message to stevep914Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am taking the F40 out for a test drive after my rear suspension adjustments, and get about 2 km and the clutch pedal goes bang, and loses all resistance. The car was in second gear, so I limped it home. The clutch works in that it drives the car, but the clutch pedal just swings freely and does not operate anything. I assume a connection somewhere between the clutch pedal and the master cylinder? Looks like a fun place to get at!! Any suggestions as to where to start, or a logical systematic checklist to follow? I know the basic principles, but have never worked on this part of a Fiero before. Thanks in advance, Steve
trotterlg
Report this Post07-21-2013 07:21 PM Click Here to See the Profile for trotterlgClick Here to Email trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
The rod probably just popped off the pin in the arm. Larry
Bloozberry
Total ratings: 308
Report this Post07-21-2013 08:45 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is the pin that Larry (trotterlg) is talking about. The spring clip may have broken off and allowed the pushrod to slip off the pin on the pedal assembly.
[This message has been edited by Bloozberry (edited 07-21-2013).]
stevep914
Report this Post07-21-2013 11:10 PM Click Here to See the Profile for stevep914Send a Private Message to stevep914Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thankyou so much guys, I will get under there tomorrow, and see what gives. The picure is superb- I love this forum! Steve
stevep914
Report this Post07-22-2013 08:14 PM Click Here to See the Profile for stevep914Send a Private Message to stevep914Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys, sure enough, the banjo fitting had popped off. The previous owner or somebody, had not used a retaining clip, but a nail with no washer between the banjo fitting, and the nail. As a result, , the nail got chewed off, and the play has caused some wear on the banjo fitting. Will probably order one of Rodney Dickman's replacements soon. Car is up and running again. Steve
