  Main bearing BOLTS, need GM part #
Main bearing BOLTS, need GM part # by Lou6t4gto
Started on: 07-19-2013 07:09 PM
Replies: 13 (832 views)
Last post by: Robertzep2 on 07-20-2013 09:38 PM
Lou6t4gto
Report this Post07-19-2013 07:09 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I need a part # for 1997 3800sc Main Cap "Bolts". Someone had listed them a few weeks ago (2450-3056), I ordered them by the part # they gave, received them, Not even close. They look more like Head bolts. (too long, different size heads) any help appreciated. Thanks
Robertzep2
Report this Post07-19-2013 08:10 PM Click Here to See the Profile for Robertzep2Send a Private Message to Robertzep2Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am who posted that list, and here is the exact part you are requesting???
http://www.tonkinonlinepart...412126/24503056.html
Lou6t4gto
Report this Post07-19-2013 08:48 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
That IS the # on the sealed "GM bag" I got. BUT, those bolts in no way shape or form FIT ! not your fault, but how am I going to get the right bolts if GMs listing is wrong ?
Robertzep2
Report this Post07-19-2013 08:57 PM Click Here to See the Profile for Robertzep2Send a Private Message to Robertzep2Edit/Delete MessageReply w/QuoteDirect Link to This Post
Did you by online or at a local dealer? I do understand your frustrations! I also understand you weren't blaming me. I just want to help, and help all of us doing this swap have good list of part numbers.
-Robert
lateFormula
Report this Post07-19-2013 10:57 PM Click Here to See the Profile for lateFormulaSend a Private Message to lateFormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lou, have you looked at the ARP catalog? They show a set of main bearing cap studs for the 3800SC engine.
http://www.summitracing.com/parts/arp-193-5401
Lou6t4gto
Report this Post07-20-2013 12:24 AM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm not doing Studs because I don't want have to get it align bored. besides, $8 is a lot better than $108. The mains in a 3800 are bulletproof, studs are a waste as far as I'm concerned. (maybe in a different engine.)
Lou6t4gto
Report this Post07-20-2013 12:59 AM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lou6t4gto
Member since May 2008
OK, this is the kind of thing that "Keeps me awake"(it's 1 am). The bolts I removed (factory) have 13mm heads, the bolts I got have 15 mm heads. The new Bolts are 3/4" LONGER than the originals, BUT, I went out and "measured" the" Depth" of the bolt holes, and they Are deep enough to get the bolts in ! This # bolt must be a 2nd design or something. AM I risking anything by using these bolts (Being so much longer ) ??
Fieroaddicted, Did you reuse you main bolts ? Or did you use these longer ones?? Or find originals ??
MarkS
Report this Post07-20-2013 10:59 AM Click Here to See the Profile for MarkSSend a Private Message to MarkSEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi,
Maybe I am missing something but the link description mentions L27 but no other type that I saw; even though applications go out to 1999?
BR's
Mark
86 SE V6 4 speed
86 SE V6 Auto
2008 G6 GT "Street" Coupe
2005 Buick 3.6 Rendezvous
2001 Olds Silhouette (AKA The Band Van)
Robertzep2
Report this Post07-20-2013 11:19 AM Click Here to See the Profile for Robertzep2Send a Private Message to Robertzep2Edit/Delete MessageReply w/QuoteDirect Link to This Post
http://www.tonkinonlinepart...ukey_product=6412126
Go to the right hand screen... down to 138. BOLT. Engine Main Bearing Cap.
ENGINE ASM-3.8L V6 PART 1 CYLINDER BLOCK AND RELATED PARTS
(L67/3.8-1); L67 - ENGINE GAS,3.8L(3.8-1),SFI,V6,SUPERCHARGED;
Scroll down on the left to the diagram of the L27 and it has the same part for the bearing cap as 24503056
Lou6t4gto
Report this Post07-20-2013 01:48 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just trying to make sure that the "Extra" 3/4" of bolt isn't going somewhere where it can do any damage.
bonaduce
Report this Post07-20-2013 02:58 PM Click Here to See the Profile for bonaduceSend a Private Message to bonaduceEdit/Delete MessageReply w/QuoteDirect Link to This Post
just checked the gm catalog 2450-3056 is for vertical bolt, used from 1997-2003, as of my last update disk (1 week ago), 24505576 is for horizontal bolt. According to GM dealer world, there is no history of a part# change, and no enginering notes about 1st or 2nd designs. dimensions should be 7/16 x 14x 3.6 This is all through gm catalog info here at work, hope this helps.
dan
Lou6t4gto
Report this Post07-20-2013 03:22 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
says 54 lbs, then 105 degrees in Chiltons(Big book), Torquespec.com says 30 lbs then 110 degrees. that's an awful big difference
MarkS
Report this Post07-20-2013 08:49 PM Click Here to See the Profile for MarkSSend a Private Message to MarkSEdit/Delete MessageReply w/QuoteDirect Link to This Post
I see it, thanks!
Maybe run a bottoming tap into those bolt holes to clean the previously unused threads for the longer bolts?
BR's,
Mark
[This message has been edited by MarkS (edited 07-20-2013).]
Robertzep2
Report this Post07-20-2013 09:38 PM Click Here to See the Profile for Robertzep2Send a Private Message to Robertzep2Edit/Delete MessageReply w/QuoteDirect Link to This Post
Guys,
For the record, I am not trying to do the "I told you so" or anything like that. I just want to make sure I have posted the right part numbers!
So, Dan (bonaduce), you have confirmed the Main Bearing and cross bolts. Could you check the others and add the GM Head bolt part number?
Main Bolts - 24503056
Main Cross Bolts - 24505576
Rod Bolts - 25531956
Rocker Arm Bolts - 24503515
Fel-Pro Head bolts - ES74033
Thanks,
-Robert
