  Frame stiffening for convertible
Frame stiffening for convertible by Treep78
Started on: 07-19-2013 02:00 PM
Replies: 12 (693 views)
Last post by: jaskispyder on 07-19-2013 08:33 PM
Treep78
Report this Post07-19-2013 02:00 PM Click Here to See the Profile for Treep78Send a Private Message to Treep78Edit/Delete MessageReply w/QuoteDirect Link to This Post
So I want to do a convertible with my fiero and I found this good reinforcement build I'de like to do. http://www.madmechanics.com...e-reinforcement.html but there is no electricity where I have to work on the car (aside from my small generator) so I asked a friend if it would work to oxy-acytoline weld it together and he said "why don't you just bolt it on?" Would that work or would bolt on reinforcement be to weak?
CowsPatoot
Total ratings: 84
Report this Post07-19-2013 02:15 PM Click Here to See the Profile for CowsPatootClick Here to visit CowsPatoot's HomePageSend a Private Message to CowsPatootEdit/Delete MessageReply w/QuoteDirect Link to This Post
The issue here is that you are not welding one flat surface to another flat surface. I suspect you will find that you don't have good locations for the bolts to hold things together.
jaskispyder
Total ratings: 205
Report this Post07-19-2013 02:16 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had a convertible fiero. The subframe was bolted in, then welded. I wouldn't go with bolts alone, as the chassis on the fiero is made up of "sheet metal" and you don't have good anchor points, like on a typically framed vehicle (truck/old car).
See this link for a x-frame: https://www.fiero.nl/forum/A...030531-2-030610.html
Treep78
Report this Post07-19-2013 02:35 PM Click Here to See the Profile for Treep78Send a Private Message to Treep78Edit/Delete MessageReply w/QuoteDirect Link to This Post
I don't want to do the x frame as you loose ground clearance and cut off access to the gas tank. The design I linked does kind of a box thing and doesn't loose clearance or the tank. Do you think a combination of bolting and welding will work?
dratts
Total ratings: 118
Report this Post07-19-2013 03:07 PM Click Here to See the Profile for drattsSend a Private Message to drattsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Archie did the strongest frame reinforcement I've seen. Check out Yarmouth Fieros build in the construction forum. Both of those are the best I've seen.
[This message has been edited by dratts (edited 07-19-2013).]
jaskispyder
Total ratings: 205
Report this Post07-19-2013 03:11 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check out the link, as the frame has a section that can be unbolted to remove tank.
Mickey_Moose
Total ratings: 144
Report this Post07-19-2013 03:42 PM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Frames are welded together for a reason - just saying. Bolt it up to get it together, then have it welded when you can move it someplace that you can do this.
Treep78
Report this Post07-19-2013 04:05 PM Click Here to See the Profile for Treep78Send a Private Message to Treep78Edit/Delete MessageReply w/QuoteDirect Link to This Post
Do you think it's possible to oxy weld it?
jaskispyder
Total ratings: 205
Report this Post07-19-2013 04:19 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
probably... depending on the quality of the welder A lot of upside-down welding.
Report this Post07-19-2013 04:38 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
For the chassis reinforcement, this is a good thread to review:
https://www.fiero.nl/forum/Forum3/HTML/000137.html
As for oxy welding... take it somewhere there is electrical service. There is a substantial amount of cutting/fitting which will be difficult if your only "tool" is a torch.
Treep78
Report this Post07-19-2013 06:17 PM Click Here to See the Profile for Treep78Send a Private Message to Treep78Edit/Delete MessageReply w/QuoteDirect Link to This Post
Good thread but I don't think I have the skills to completely replace structural pieces of the car. As for welding I'm trying to figure out if between my Jeep and my portable generator I have the juice to run an arc welder.
Treep78
Report this Post07-19-2013 06:57 PM Click Here to See the Profile for Treep78Send a Private Message to Treep78Edit/Delete MessageReply w/QuoteDirect Link to This Post
Treep78
Member since Feb 2013
Actually, new question: can I use my portable generator to help my alternator recharge my battery to run an arc welder off a 120v inverter?
jaskispyder
Total ratings: 205
Report this Post07-19-2013 08:33 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rent a portable welder/generator or trailer car to a location with power
