  Tach & Fuel gauge stoped working at the same moment?
Tach & Fuel gauge stoped working at the same moment? by 1fast2m4
Started on: 07-13-2013 09:06 AM
Replies: 3 (123 views)
Last post by: Arns85GT on 07-13-2013 07:18 PM
1fast2m4
Report this Post07-13-2013 09:06 AM Click Here to See the Profile for 1fast2m4Send a Private Message to 1fast2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
I was just driving along and noticed that my Tach was just sitting on 0rpm and my fuel gauge was pegged way fast full? Is there a common issue when the both stop at the same moment? they where working yesterday but not now. Spedo still works.
I'm amusing it's likely a cluster issue, maybe a good time to swap in my GT 120mph cluster.
1986 SE 3800SC/4t65eHD (12.871@104.96) I'll Sell it if you like
1985 GT 3800SC (swap in progress)
Report this Post07-13-2013 11:51 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
When the fuel gauge goes high you have infinite resistance....a break in the circuit....so I would check the ground.
jb1
Report this Post07-13-2013 02:05 PM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
mine was bad. connection. on. left rear of panel. when my tach an fuel guage stopped working...
87 GT
(series II swap in progress)
85GT Northstar
86GT 3800 n/a
Arns85GT
Total ratings: 202
Report this Post07-13-2013 07:18 PM Click Here to See the Profile for Arns85GTSend a Private Message to Arns85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
The plugs on the back have copper leads, and they pressure fit into the foil leads. If they get a bit of corrosion, you could easily lose both at once.
I'd clean those contacts with electronics contact cleaner and some fine sand paper. Gentle, but get them shiny.
That is the first thing to do.
Arn
