  Fuel pump wiring, how do i remove it?
Fuel pump wiring, how do i remove it? by don297
Started on: 07-12-2013 09:53 AM
Replies: 2 (306 views)
Last post by: Tweeder on 07-12-2013 01:01 PM
don297
Report this Post07-12-2013 09:53 AM Click Here to See the Profile for don297Send a Private Message to don297Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am replacing my fuel pump, and i have the tank ready to drop, but the wiring will not come off! it is still connected somehwere though but i cant tell where it is! Can anyone help by giving me a good picture of where the wiring disconnects for the fuel tank? This is an '84 auto.
Total ratings: 290
Report this Post07-12-2013 10:55 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
The fuel pump power feed is a single weatherpack connector on a tan/white wire close to the pass through on the firewall in the engine compartment.
The two gauge wires I believe are on a double weatherpack connector on the passengers side near the firewall also but I am not sure on the 84.
Tweeder
Report this Post07-12-2013 01:01 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah if you remove the heat shield that goes on the back of the cabin, you will be able to follow the wire harness up to the connector.
86 GT Convertable 3800sc
