  wire ends for 203/500 ?
wire ends for 203/500 ? by Lou6t4gto
Started on: 07-11-2013 08:34 PM
Replies: 13 (200 views)
Last post by: Will on 07-15-2013 02:37 PM
Lou6t4gto
Report this Post07-11-2013 08:34 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I bought the New 203 and 500 for my swap. I haven't gotten them yet, but I suspect that the wire ends that pin into them are different. Does anyone know the "source" where I can buy some ? Thanks
Jncomutt
Total ratings: 221
Report this Post07-11-2013 09:19 PM Click Here to See the Profile for JncomuttSend a Private Message to JncomuttEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've purchased all my terminals from mouser. I'd assume they have the C500/C203 pins as well, never looked, however.
seajai
Total ratings: 51
Report this Post07-11-2013 10:48 PM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
http://terminalsupplyco.com...CAT=54221#Categories
IIRC the C203 uses the unsealed metri-pack 280 terminals, and the C500 is a mix of 280 and 480.
http://terminalsupplyco.com...CAT=53165#Categories
[This message has been edited by seajai (edited 07-11-2013).]
Lou6t4gto
Report this Post07-11-2013 11:07 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I only need like 5 or 10 of each. there is a min order of $20 ! anyone got any ? Thanks
Total ratings: 290
Report this Post07-12-2013 11:01 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, tell me how many of each type. Figure 0.75 each plus 1.50 for shipping.
You also will never get them to crimp properly without the PROPER crimp too. Any crimp tool sold at a hardware store won't work properly. Search Metripack crimp tool - Here is one of the cheaper ones. - http://www.ebay.com/itm/MET...em4d092b021a&vxp=mtr
You can always crappy crimp them and then solder them as long as you don't over run the solder into the contact area or the tang or leave big solder drips on the terminal.
[This message has been edited by phonedawgz (edited 07-12-2013).]
Total ratings: 236
Report this Post07-12-2013 11:25 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
CarQuest carries 5 and 10 packs of metri-pack terminals.
Lou6t4gto
Report this Post07-13-2013 08:21 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
no carquest here.
Total ratings: 236
Report this Post07-14-2013 05:27 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lou6t4gto
Report this Post07-14-2013 07:04 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
which 280s do I need, the large female or small (terminal size, not wire size), and Do I need any male terminals ? I've got the New empty 500 and 203, and nothing to go by on the car end. thanks
Total ratings: 290
Report this Post07-14-2013 07:12 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
203 are all female
C500 are all male - A4, A5 and the entire E row are the larger terminals.
Lou6t4gto
Report this Post07-14-2013 07:19 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
ah, Thank you.
Total ratings: 236
Report this Post07-15-2013 11:20 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
280 *IS* the terminal size. That's the nominal width of the connection in mm's. (IE, it's 1/8" wide).
Originally posted by phonedawgz:
203 are all female
One side of the connector uses female. The other side *MUST* use male or it's impossible to make a connection.
I don't remember which side is which right now.
Lou6t4gto
Report this Post07-15-2013 01:11 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
OK, I thought 280 was the "style", not size.
Total ratings: 236
Report this Post07-15-2013 02:37 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Metri-Pack is the style. All the metri-pack sizes are mm equivalent of inch sizes... 160, 280, 480, etc.
Pins of the same size can vary by male/female, wire gauge, push to seat/pull to seat, etc.
