| quote | Originally posted by fast40driver:
Just the quick check - you are using the big guy's entry/exit, right? Back up to the door, sit down sideways, twist your torso and swing your legs in. Reverse to get out, twisting sideways, then hands on the roof to help you pull yourself up.
Sorry if this is old hat for you, just had to run it by you.
Mike |
I am only 5' 10" and 175lbs and I have to get in this way. What is wrong with me? (My leg gets wedged under the steering wheel)
OP, can you get us pics when the quick release is installed? I'm curious how much closer the steering wheel will be to the seat.
Good luck.
