  3800 flywheel not cut properly, ruined???
3800 flywheel not cut properly, ruined??? by sco77
Started on: 07-06-2013 05:48 PM
Replies: 3 (290 views)
Last post by: sco77 on 07-06-2013 06:06 PM
sco77
Report this Post07-06-2013 05:48 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
So I just did some measuring and turns out the machine shop that did my flywheel didn't cut it down to 0.820 like I instructed, it was balanced to the flex plate but not cut down... Is this flywheel ruined? the balancing holes were drilled in the back side, if it gets cut down to 0.820 wont the holes then be taking away too much weight and cause serious balance problems? Can it be fixed or did they ruin it?
Everything imaginable is stopping me from doing my swap.
86 Fiero GT 4spd - (pending L67 swap: VS cam, GenV) Build Progress eta: 8/13
98 GTP - Some mods
hookdonspeed
Total ratings: 131
Report this Post07-06-2013 05:52 PM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
ouch, they can fill and re-drill holes, but im not sure if id want that flywheel... :/
id personally take it back and raise hell... specially if it was Burtonsville machine, they cant get anything right :/
[This message has been edited by hookdonspeed (edited 07-06-2013).]
trotterlg
Report this Post07-06-2013 05:59 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have them cut it down and check the ballance, if the holes have taken too much off one side they can drill the other side, you will just end up with a lighter flywheel which could be a good thing. Larry
sco77
Report this Post07-06-2013 06:06 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by trotterlg:
Have them cut it down and check the balance, if the holes have taken too much off one side they can drill the other side, you will just end up with a lighter flywheel which could be a good thing. Larry
Yeah they are redoing it... I guess as long as it can be corrected its not too bad... And the more weight that can be taken off the better. I just worry too much I guess.
98 GTP - Some mods
