  FYI: '87 Base Coupe Corner Weights
FYI: '87 Base Coupe Corner Weights by Cheeze_87
Started on: 06-28-2013 05:26 PM
Replies: 2 (207 views)
Last post by: theogre on 06-29-2013 02:53 PM
Cheeze_87
Report this Post06-28-2013 05:26 PM Click Here to See the Profile for Cheeze_87Send a Private Message to Cheeze_87Edit/Delete MessageReply w/QuoteDirect Link to This Post
In case anyone was wondering. Scale is up to date on calibration and accurate. Yes the tires are completely on the pads alone (just barely).
Stock
2.5L
5 Speed
13" Aluminum wheels / tires
~1/3 Tank Gasoline
Spare tire / jack included
LF: 568
RF: 510
LR: 699
RR: 767
Total: 2544 lbs
Ang84Indy
Report this Post06-28-2013 09:39 PM Click Here to See the Profile for Ang84IndySend a Private Message to Ang84IndyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for posting! I own one of those.
Report this Post06-29-2013 02:53 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Interesting.
maybe Weight is good or has errors... total is w/in the ballpark.
Why? Most scales have problems accurately reading the load at edge of platform.
If you can, Try doing one axle at a time that centers the load on 2 scales and see if weight changes.
(total weight is just sum of scales.)
You can try contact scale maker... Avery Weigh-Tronix (Avery/ITW is current owners of Weigh-Tronix)
