  at the 30th finally made it and need HELP!!!
at the 30th finally made it and need HELP!!! by mmeyer86gt/gtp
Started on: 06-27-2013 05:38 PM
Replies: 20 (570 views)
Last post by: VikingRedBaron on 07-01-2013 10:51 PM
mmeyer86gt/gtp
Total ratings: 73
Report this Post06-27-2013 05:38 PM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got the car 30 min from indiana and it started to back fire I think it is the cat anyone know an easy way to do a straight pipe in the parking lot / fix the cat???
I am walking around with my PFF mmeyer shirt on HELP
Shonyman32
Report this Post06-27-2013 05:46 PM Click Here to See the Profile for Shonyman32Send a Private Message to Shonyman32Edit/Delete MessageReply w/QuoteDirect Link to This Post
Go to autozone or any other auto parts store. Buy 2 pieces of piping. 3 U clamps. Get the right size piping. Of course you will need a cutting tool.
mmeyer86gt/gtp
Total ratings: 73
Report this Post06-27-2013 05:48 PM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
Stock size is 2 1/2 or 2 1/4 anyone have a cutting tool??
TWright
Report this Post06-27-2013 07:05 PM Click Here to See the Profile for TWrightSend a Private Message to TWrightEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are you sure its the Cat? I have had several failed Cats. Here are the symptoms: 1.) Loss of power (no missing or anything, just won't rev) , 2.) The Cat Rattles, or 3,) If you have an OBD2 car (which most Fieros are not) it will set the Check Engine Light on.
I don't think yours is a Cat. Is your distributor cap cracked? That will cause backfiring.
(BTW, I live in Indianapolis and I have a Sawzall. I would be happy to bring it, but I don't think that's the problem.
mmeyer86gt/gtp
Total ratings: 73
Report this Post06-27-2013 08:01 PM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
Symptoms are car was driving perfectly fine for 2 hours then when I pressed hard on the gas it started to back fire then I could flutter the gas and drive a bit like a mile or two more then after 5 miles of this the car finnally was making a lot of puffing sounds and then died. Now after the car sat for 5 minutes it started right up to get onto a trailer. And after bringing it into indy I can start the car and drive it up and down the street it did not show sounds of puffing or backfiring. Cat? Map? At this point if it is a cat just a drill to drill out the cat would probably help.
[This message has been edited by mmeyer86gt/gtp (edited 06-27-2013).]
James Bond 007
Total ratings: 263
Report this Post06-27-2013 08:12 PM Click Here to See the Profile for James Bond 007Send a Private Message to James Bond 007Edit/Delete MessageReply w/QuoteDirect Link to This Post
Might be a torn fuel pressure regulater.If it continues to back fire and run rich.I don't think its the cat.
Hudini
Total ratings: 165
Report this Post06-27-2013 09:03 PM Click Here to See the Profile for HudiniSend a Private Message to HudiniEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like the Ignition Control Module. Heats up and dies, then cools off and runs fine.
Purple86GT
Total ratings: 62
Report this Post06-27-2013 10:05 PM Click Here to See the Profile for Purple86GTSend a Private Message to Purple86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bingo!
86 toy
Report this Post06-27-2013 10:19 PM Click Here to See the Profile for 86 toySend a Private Message to 86 toyEdit/Delete MessageReply w/QuoteDirect Link to This Post
ding ding ding we have a winner!!! :-D
fierocarparts
Report this Post06-27-2013 11:22 PM Click Here to See the Profile for fierocarpartsSend a Private Message to fierocarpartsEdit/Delete MessageReply w/QuoteDirect Link to This Post
My fuel pump had these symptoms. If you really suspect CAT, knock a hole in pipe in front of it. Easily welded if not the problem.
Phirewire
Report this Post06-27-2013 11:44 PM Click Here to See the Profile for PhirewireSend a Private Message to PhirewireEdit/Delete MessageReply w/QuoteDirect Link to This Post
My money is here, bum a spare from someone at the show there are probably upwards of 50 spares at the show. everyone should carry a spare.
Bruce
Report this Post06-27-2013 11:55 PM Click Here to See the Profile for BruceSend a Private Message to BruceEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mine did that, and it turned out to be one of the vacuum lines.
86GT 4 speed.
bb
mmeyer86gt/gtp
Total ratings: 73
Report this Post06-28-2013 12:27 AM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have 5 with me so I will try one of those.
msrservices
Report this Post06-28-2013 01:30 AM Click Here to See the Profile for msrservicesClick Here to visit msrservices's HomePageSend a Private Message to msrservicesEdit/Delete MessageReply w/QuoteDirect Link to This Post
When my cat went bad, I was able to discount the clamp at the Y pipe. That allowed enough exhaust to exit the engine to prove I had a blockage. I removed the cat after that and had no problems.
smartaxel
Total ratings: 83
Report this Post06-28-2013 11:11 PM Click Here to See the Profile for smartaxelClick Here to visit smartaxel's HomePageSend a Private Message to smartaxelEdit/Delete MessageReply w/QuoteDirect Link to This Post
That doesn't sound like a cat to me. How about a leak in the exhaust somewhere? I had a pipe separate just before the CAT, and unburnt air kept getting in and making a backfire noise/feeling. Fixed the leak and the "backfire" went away. Or, unburnt fuel. You sure all the spark pliug wires are making good contact, distributor is good, and tyou're getting spark at all plugs? Ignition control modules (that I've had) just plain die (car stops) then when cool, it starts and runs. I've never had one cause a bakcfire though.
Bruce
Report this Post07-01-2013 11:25 AM Click Here to See the Profile for BruceSend a Private Message to BruceEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you find the problem?
bb
mmeyer86gt/gtp
Total ratings: 73
Report this Post07-01-2013 11:49 AM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
Found the problem to be broken screw on the distributor cap causing the cap to vibrate around. Also i just put a new rebuilt caliper on the rear and t it ripped in 1/2 when i left indy. Fun fun at the show!
Report this Post07-01-2013 12:08 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
You broke a rebuilt caliper in half??? I fail to understand how that could happen unless one of the caliper bolts was not fastened through correctly. The good news it that it can be fixed.
Although it sounds like you hit a few bumps in the road., at least you have the fun times at the 30th to remember.
mmeyer86gt/gtp
Total ratings: 73
Report this Post07-01-2013 05:22 PM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
I will post pics wjen i get a chance the front face ripped off the outer brake pad was completely missing the piston was pushed out of the caliper no seal was left and none of the caliper bolts failed.
Report this Post07-01-2013 07:56 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like one of the brake pads may have come apart. Did you bleed the brake system, fully exercise the hand brake, and worked the pedal before using the new brake calipers? Can't say that the caliper just didn't fail but this sounds weird.
VikingRedBaron
Report this Post07-01-2013 10:51 PM Click Here to See the Profile for VikingRedBaronSend a Private Message to VikingRedBaronEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just for the record, to verify when my exhaust was plugged on my Formula, I took the bolts out of the EGR valve and created a leak there.
The car started, I put the EGR back on and cut the cat off.
