  Crap...BAAAAD rod knock in my 3800sc. Or rather if I didn't have Bad luck..... etc
Crap...BAAAAD rod knock in my 3800sc. Or rather if I didn't have Bad luck..... etc by deezil
Started on: 06-11-2013 06:19 PM
Replies: 20 (1803 views)
Last post by: Dennis LaGrua on 09-01-2013 07:41 AM
deezil
Report this Post06-11-2013 06:19 PM Click Here to See the Profile for deezilSend a Private Message to deezilEdit/Delete MessageReply w/QuoteDirect Link to This Post
Horrible week for us with cars and other engine driven machines.
Wifes car developed a intermittent no start leaving her and our 4 month old stranded in the stl heat. Took 3 days of searching for the dealer to find out a ground under the dash broke loose. Had to ride a Honda Helix that I restored from ground up back and forth to work and on the HWY the brand new Honda Wheel bearings disintegrated at 65mph almost causing me to wreck.
This Morning I Pulled fiero out to drive it back and forth and it has developed a load lower end rattle... Like real bad rattle. Have about 3k in it since it was installed.
What a Nightmare week.. What the crap did I do for this bad karma..
trotterlg
Report this Post06-11-2013 06:53 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Funny how the 3800's are bullet proof in a Buick but when you put them in a Fiero all sorts of bad things happen to them. Larry
Phil
Total ratings: 154
Report this Post06-11-2013 08:56 PM Click Here to See the Profile for PhilSend a Private Message to PhilEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are you sure that the rattle isn't from the SC pulley?
deezil
Report this Post06-11-2013 08:58 PM Click Here to See the Profile for deezilSend a Private Message to deezilEdit/Delete MessageReply w/QuoteDirect Link to This Post
I cut the belt of the sc and stopped it with my hand. Its definetly from the lower part of the engine. Its a low hollow knock
Justinbart
Total ratings: 119
Report this Post06-11-2013 09:09 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Garbage motors.
Turbo 3800 E85 F23 5spd spec5
11.17@132.6
deezil
Report this Post06-11-2013 09:19 PM Click Here to See the Profile for deezilSend a Private Message to deezilEdit/Delete MessageReply w/QuoteDirect Link to This Post
well...
Another garbage motor is going back into it!
solotwo
Total ratings: 62
Report this Post06-11-2013 09:50 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Man I thought I had it bad with this pos 3800 I bought several months ago. Dude may be you should by a lottery ticket. I hope things get better for you and your family!
deezil
Report this Post06-11-2013 10:26 PM Click Here to See the Profile for deezilSend a Private Message to deezilEdit/Delete MessageReply w/QuoteDirect Link to This Post
Such is life. I broke a lot of hearts with this greasy 145k motor Mike gonzales cleaned up and made look a gem. Ill find another and stab it in and keep breaking more hearts. May take me a bit it seems like the series 2 engines are really dried up around here though as of late.
DefEddie
Report this Post06-11-2013 11:58 PM Click Here to See the Profile for DefEddieSend a Private Message to DefEddieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I swapped my wife's n/a for a low mileage L67,blew trans in 100 miles.
Rebuilt trans,spun rod in 100 miles.
Installed low mileage L67,spun bearing (not sure which yet).
Rebuilt previous n/a into a top swap and ceramic or moly coated every moving part including bearings.
150 miles so far,feels great
It'll always get better,cause there has to be a point where it can't get worse.
Darth Fiero
Total ratings: 361
Report this Post06-12-2013 02:59 PM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've done over a dozen 3800 swaps for customers (not counting those I've done for myself, family, and friends) and I have yet to hear of any failures except one. The one failure occurred only after the owner put the car in storage (this after he drove it hundreds of miles). He let a friend drive it when he was moving and he said the friend took it out of the storage unit and beat the snot out of it when it was cold. Beating on anything when it is cold is bad, and the oil probably needed to be changed before it was driven after it sat in storage as long as it did.
I change the problem gaskets on pretty much all the 3800 swaps I do but you have to take great care when cleaning the gasket mating surfaces and make absolutely sure no dirt or grit gets into the engine when it is "open". Most 3800 engine failures can be attributed to contaminated oil - contaminated either from antifreeze (due to leaking lower intake gaskets) or from grit/dirt that was introduced when replacing certain gaskets or any other internal engine component (and even from using improper gasket removal techniques or tools). I've seen pictures of guys putting engines together outside in their driveways with the everyday dust and dirt blowing around and they wonder why their engines don't last. Basically you need a "clean room" to assemble an engine to make sure no debris is able to get into it and you need to make sure you thoroughly cleanse the inside of the engine just prior to final assembly.
The preceding is true for any engine as a matter of fact. I don't care if you have a 4 banger or V8. If you allow dirt and grit to get inside the engine while it is apart and you don't clean it out - it won't last long.
-ryan
OVERKILL IS UNDERRATED
Justinbart
Total ratings: 119
Report this Post06-12-2013 03:15 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
I agree 100%. I even flush $50 worth of oil through it before the first drive.
11.17@132.6
deezil
Report this Post06-12-2013 05:42 PM Click Here to See the Profile for deezilSend a Private Message to deezilEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mine was never cracked open. And it for sure had plenty of oil changes. It just let a bearing go.. Stuff happens.
Hopefully a few of these local L67's for sale pan out and I can get it back up on the road sooner than later.
Lou6t4gto
Report this Post06-12-2013 05:56 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
After tearing down my 3800,(been building my own engines for 40 years), these 3800SCs , the main bearings are pretty much bullet proof, the rod bearings, even after 200K miles they show no "wear" . even if they have had just minimal "CARE", someone would have to work real hard to blow one. By that I I mean running with no Oil, Low oil, never changing the oil, No coolant, revving it until it won't go any higher. If a 3800 gives it up, it's usually due to "operator error" somewhere along the road. I don't care for" 1 time use Bolts", but one of the best engineered engines I've seen.
deezil
Report this Post06-12-2013 06:27 PM Click Here to See the Profile for deezilSend a Private Message to deezilEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just not the case with this engine. This engine was from a 1 owner car with a stack of records for dealer maintenance. Up until the month it got t-boned.
It sat for maybe 3 months and then was installed with a rattle can rebuild From Mike Gonzales here on the forum. It has had maybe 4 Oil changes since I got it back and Mike did one when he installed it.
I haven't ran this car near as hard as the Buick regal GS I had. It's been a sunny day driver and the Bad knocking happend on start up when it was already warm.
Stuff happens. This engine was never neglected and I never neglected it. It just went.
Justinbart
Total ratings: 119
Report this Post06-12-2013 07:11 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you don't put at least 5.5 qts in and take hard left turns It will run out of oil in a turn. I lost one like this.
11.17@132.6
sco77
Report this Post06-12-2013 08:30 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
I think this is because 1 of 2 things...
First thing is most Fiero engines are junk yard engines or from badly wrecked cars, these can be ticking time bombs.
Second thing is people who are unaware of these engines may just slap new rod bearings in, etc, which with these engines you simply can't do without proper procedures, the success rate can be VERY low that they will last more than 1000 miles.
86 Fiero GT 4spd - (pending L67 swap: VS cam, GenV) Build Progress eta: 8/13
98 GTP - Some mods
Lou6t4gto
Report this Post06-12-2013 09:09 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
"Hard left turns it runs out of oil" ?! Sounds like a oil "baffle" in the Pan is in order. Now who would do" hard left turns" in a Fiero ? LOL
there's your answer "why they last in a Buick and not in a Fiero (Most Buick owners drive them "Gently")
My pan is still off, I think I'll look into making a "Baffle". Has anyone done it " or "are they Offered" aftermarket ?
deezil
Report this Post06-12-2013 09:51 PM Click Here to See the Profile for deezilSend a Private Message to deezilEdit/Delete MessageReply w/QuoteDirect Link to This Post
I never ran this 3800 hard and yes it was always marginally over filled with oil...
Life goes on... Someone find me a Replacement 3800sc stat!
hercimer01
Report this Post06-14-2013 12:31 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just had an episode with mine where at first I thought the SC had gone out. Eliminated that. Then I thought it could be a collapsed lifter Or a cracked flex plate. I would get a God awful noise when the motor was under load. I swapped out the Coils and ICM, thats where I discovered A bad plug wire.
The metal retainer had broken off inside the boot and I hadn't noticed it.
I replaced the wires with new and did a case learn on the computer because I think they were swapped around too.
No more noise.
Good Luck Bro.
88 Coupe under construction
deezil
Report this Post09-01-2013 03:41 AM Click Here to See the Profile for deezilSend a Private Message to deezilEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally found a Low Mile 3800sc and had a Local Shop My Friend runs put it in.
The Whole time he was sending me text's on how well the Quality of the install Mike Gonzalez originally did.
So back up and running. Now to get the A/C sorted out.
Report this Post09-01-2013 07:41 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
An engine that blew after 147K miles has certainly given a useful life. Many factors could have contributed to its failure but driving an old worn high mileage engine hard could be one of them. The 3800 engines are durable but as soon as one owner changes the driving pattern that it has been exposed to all its life; its a whole new ballgame. Installing any used engine is a crapshoot. Most of the time they work but sometimes they don't.
