  torson rods on deck lid
torson rods on deck lid by ironhead.76
Started on: 04-10-2013 10:08 PM
Replies: 7 (461 views)
Last post by: gtoformula on 07-14-2013 08:04 PM
ironhead.76
Report this Post04-10-2013 10:08 PM Click Here to See the Profile for ironhead.76Click Here to visit ironhead.76's HomePageSend a Private Message to ironhead.76Edit/Delete MessageReply w/QuoteDirect Link to This Post
Has anyone changed hinges on the deck lid with out breaking the rear glass?
Dodgerunner
Total ratings: 323
Report this Post04-10-2013 10:35 PM Click Here to See the Profile for DodgerunnerClick Here to visit Dodgerunner's HomePageSend a Private Message to DodgerunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
All the time. I just removed the springs from some hinges since I put gas springs on.
Get a strap clamp with hooks. Hook on the bottom loop where the pin is in the hinge. Hook the other end to the trunk lip and pull the bottom end of the spring rearward until you can remove the pin. Then release the spring.
Repeat on the other side. Once you have that done you can pop the springs out of the fingers under the rear window and you home free to remove the hinges.
Report this Post04-11-2013 07:07 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dodgerunner has it right but I choose to anchor the hold down straps to a large tree with a tow strap. I then ratchet the torsion spring away from the holding pin and pull the holding pin out. Then I release the strap ratchet and relax the torsion springs . At this point they can be removed safely by hand. If you use this method there is little to no chance of breaking the rear window.
fierosound
Total ratings: 286
Report this Post04-11-2013 07:11 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Look here (with instructions from Service Manual)
https://www.fiero.nl/forum/A...130314-1-077596.html
zmcdonal
Report this Post04-11-2013 09:53 PM Click Here to See the Profile for zmcdonalSend a Private Message to zmcdonalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah I learned how much tension those things have on them one day at the junkyard. I unbolted the hinges and had my had on the top of the hinge, it didn't break out the window but I sure wont do it that way again. After I had them loose I noticed the pins. Haha.
gtoformula
Report this Post07-13-2013 03:14 PM Click Here to See the Profile for gtoformulaSend a Private Message to gtoformulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
1986 GT. I removed the decklid wing, but now the torsion rod tension is too much. If I pop the decklid switch I've got to have my other hand at the rear of the roof to catch the lid ... it flies up too fast. I have the service manual and have read this thread, but wanted to know if anyone has an alternative process for removing the torque rod retaining pin. The torque rod sits over the top of the pin and needs to be moved rearward before the pin can be removed. Not looking forward to finding a come a long and backing up to a tree to move the torque rod. Doesn't seem to be enough room to get a pry bar back there so maybe that's what I'll need to do. The service manual just states to move the pin forward or backward to increase/decrease tension. Says nothing about how to move the torque rod. Any thoughts?
Report this Post07-14-2013 12:23 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rachet tie down to pull it back, move pin, relief pressure....
gtoformula
Report this Post07-14-2013 08:04 PM Click Here to See the Profile for gtoformulaSend a Private Message to gtoformulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks olejoedad,
I think that I'll head over to Lowe's and buy a ratcheting tie down. I've got a bunch of trees in my yard so I'll just back the car up to one and use my standing lumber as an anchor for the tie down.
