  Will these wheels fit 225/40/18 +35 offset
Will these wheels fit 225/40/18 +35 offset by ionstorm666
Started on: 04-08-2013 06:22 PM
Replies: 12 (770 views)
Last post by: Fierotregg on 08-05-2013 04:05 PM
ionstorm666
Report this Post04-08-2013 06:22 PM Click Here to See the Profile for ionstorm666Send a Private Message to ionstorm666Edit/Delete MessageReply w/QuoteDirect Link to This Post
The car is a stock 87 gt.
Will 225/40/18 on 18x8 rims with a +35 offset fit without rubbing?
Thanx in advance.
Total ratings: 463
Report this Post04-08-2013 08:16 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Shouldn't be a problem.
rogergarrison
Total ratings: 551
Report this Post04-09-2013 01:30 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
make sure theyre 100mmx5 lug pattern
ionstorm666
Report this Post04-09-2013 07:50 PM Click Here to See the Profile for ionstorm666Send a Private Message to ionstorm666Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanx for the responses guys.
They are 5x100, was just afraid they might rub on either the suspension or fenders.
ShaneSAW
Report this Post04-09-2013 09:05 PM Click Here to See the Profile for ShaneSAWSend a Private Message to ShaneSAWEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dont know about the offset but thats what i run on my SE, soon to be something else don't like the 18's it has on it (not my choice)...
Report this Post04-09-2013 09:23 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed a set of four 17"wheels/tires today and they fit fine. Used 17 x 7.5"W Sport wheels 35mm offset. Goodyear Eagle 1 225 x 45 x 17 in back and 205 45 x17 front. A friend of mine installed 18" and had problems with the tires hitting the wheel wells in front but his car was lowered 1" . Not sure about 18" size wheels but if Raydar says that they fit he probably uses a specific formula.
Total ratings: 463
Report this Post04-09-2013 09:57 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
... Not sure about 18" size wheels but if Raydar says that they fit he probably uses a specific formula.
No specific Formula. Just that 35mm seems to be the ideal offset for pre 88 Fieros, as long as the widths aren't absurd.
With a 225 section width, the shoulders of the tire are going to be in the same place on a 7" wheel as they will on an 8" wheel.
ionstorm666
Report this Post04-09-2013 10:25 PM Click Here to See the Profile for ionstorm666Send a Private Message to ionstorm666Edit/Delete MessageReply w/QuoteDirect Link to This Post
One more will they fit question.
The second set of rims I am considering are 17x7 +40mm offset. With these wheels I would likely go with 205/45/17 front and 215/45/17 back.
Are these likely to rub since the wheels would be closer to the suspension? I have heard 40mm works and also heard it doesn't.
Blacktree
Total ratings: 350
Report this Post04-09-2013 10:31 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have 17x7" wheels with 40mm offset on my '87 SE. They fit fine.
Total ratings: 463
Report this Post04-10-2013 05:41 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
What is the section width of your rear tire? How close are you to the springs/struts/perches?
40mm is close. It may depend on tire fitment whether it will rub or not.
NetCam
Report this Post08-05-2013 12:13 AM Click Here to See the Profile for NetCamClick Here to visit NetCam's HomePageSend a Private Message to NetCamEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have 17x7/40 offset with 215/45 all around with no problems.
[This message has been edited by NetCam (edited 08-05-2013).]
Lou6t4gto
Report this Post08-05-2013 02:07 AM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Might be "Close" at the spring seats, unless you have coil overs
Fierotregg
Report this Post08-05-2013 04:05 PM Click Here to See the Profile for FierotreggSend a Private Message to FierotreggEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's the size I'm running on mine, no fitment problems
