  radio antenna
radio antenna by Bruce
Started on: 03-30-2013 08:13 PM
Replies: 5 (676 views)
Last post by: Patrick on 10-30-2013 05:16 PM
Bruce
Report this Post03-30-2013 08:13 PM Click Here to See the Profile for BruceSend a Private Message to BruceEdit/Delete MessageReply w/QuoteDirect Link to This Post
Will the radio antenna unscrew as just the antenna itself, or is it directly attached to the cable?
Report this Post03-30-2013 09:01 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
There are little flats on the base of the antenna that take a 7/16" end wrench I think.....then it unscrews.
[This message has been edited by Gall757 (edited 02-05-2019).]
oldbikeracer
Report this Post03-31-2013 10:23 AM Click Here to See the Profile for oldbikeracerClick Here to visit oldbikeracer's HomePageSend a Private Message to oldbikeracerEdit/Delete MessageReply w/QuoteDirect Link to This Post
If it has never been removed it may be rusted up and impossible to remove. Try spraying it with PB Blaster or some other rust buster and let it sit for a day and then try removing it.
James Bond 007
Total ratings: 263
Report this Post03-31-2013 11:20 AM Click Here to See the Profile for James Bond 007Send a Private Message to James Bond 007Edit/Delete MessageReply w/QuoteDirect Link to This Post
Remove the screws that hold the inner fender well on,then use a flash light to see what your going to be working with.Its been a long time since I replaced an antenna,but it was fairly easy.You should get a new,base nut (or what ever holds it on),with the new antenna.
Vernon8360
Report this Post10-30-2013 08:46 AM Click Here to See the Profile for Vernon8360Send a Private Message to Vernon8360Edit/Delete MessageReply w/QuoteDirect Link to This Post
What are the thread specifications for the original antenna?
Total ratings: 466
Report this Post10-30-2013 05:16 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
The antenna unscrews from a base mounted under the fender. It's this base which is attached to the cable.
[This message has been edited by Patrick (edited 10-30-2013).]
