  Where can I buy TCC solenoid, TCC pressure switch, and side pan gasket other than TFS
Where can I buy TCC solenoid, TCC pressure switch, and side pan gasket other than TFS by Timpilot
Started on: 03-19-2013 09:08 PM
Replies: 7 (379 views)
Last post by: carbon on 07-19-2013 01:33 PM
Timpilot
Report this Post03-19-2013 09:08 PM Click Here to See the Profile for TimpilotClick Here to visit Timpilot's HomePageSend a Private Message to TimpilotEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Fiero Store seems a little high on the price of these items but I haven't found them elsewhere.
Thanks for any help.
Timpilot
88FieroGT TTops
Report this Post03-19-2013 09:22 PM Click Here to See the Profile for 88FieroGT TTopsSend a Private Message to 88FieroGT TTopsEdit/Delete MessageReply w/QuoteDirect Link to This Post
TFS gives you a 10% discount for being on PFF---but you can also go to rockauto
86soon3.4
Report this Post03-19-2013 09:38 PM Click Here to See the Profile for 86soon3.4Send a Private Message to 86soon3.4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Any tranny shop should have it.
That's where I get them.
Steve
Marvin McInnis
Total ratings: 227
Report this Post03-20-2013 01:33 PM Click Here to See the Profile for Marvin McInnisClick Here to visit Marvin McInnis's HomePageSend a Private Message to Marvin McInnisEdit/Delete MessageReply w/QuoteDirect Link to This Post
RockAuto.com?
GMPartsDirect.com?
FieroStore.com?
local auto parts store?
local GM dealer?
local transmission specialty shop?
A GM dealer or a transmission specialty shop may be the only places you're going to find the side cover gasket, but it's not that expensive.
[This message has been edited by Marvin McInnis (edited 03-20-2013).]
jaskispyder
Total ratings: 205
Report this Post03-20-2013 01:43 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any auto parts store should be able get these parts.
If not, I have had good luck with Rock Auto. They list it as the control solenoid under auto tranny
https://www.rockauto.com/catalog/moreinfo.php?pk=428950&cc=1249208
Advance can get them: http://shop.advanceautopart...olenoid+transmission
Amazon:
Fel-Pro TOS18661 Oil Pan Set
ACDelco 8689901 Torque Converter Solenoid
ATP CE-4 Automatic Transmission Control Solenoid
[This message has been edited by jaskispyder (edited 03-20-2013).]
Timpilot
Report this Post03-20-2013 10:17 PM Click Here to See the Profile for TimpilotClick Here to visit Timpilot's HomePageSend a Private Message to TimpilotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks a bunch for all the help. I ordered the solenoid and side-cover gasket from Rock Auto.
Could not seem to find the pressure switch. I thought I would go ahead and replace the pressure switch while I have the side-cover off.
a_bartle
Report this Post07-19-2013 10:45 AM Click Here to See the Profile for a_bartleSend a Private Message to a_bartleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I notice the AC Delco solenoid (#8689901) has extra wire and connectors on the ends, the other solenoids just have short leads and a wire connector on the end (which means you'll be cutting into the original wires and making a connection). Usually I'd not want to do that because it's just another place for a possible failure, however, is it a pain-in-the-ass to route the wires and make the connections if I order and use the AC Delco solenoid when installing the part???
Also, I'm a little confussed about the "pressure switch". Is this also refered to as a "3rd gear switch". I'm having trouble finding that part anywhere (I did find it as a pressure switch at the Fiero Store, but wanted to make sure it was the same thing as the 3rd gear switch...).
[This message has been edited by a_bartle (edited 07-19-2013).]
carbon
Total ratings: 130
Report this Post07-19-2013 01:33 PM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
The pressure switch is the 3rd gear switch and yes it is a pain in the rear to get your fingers in there, between the valve body and the case, to mess with the wiring, I ended up cutting and splicing even with the ACDelco kit... wasn't really a big deal and the connectors already installed for the pressure switch was nice as well.
On Rock Auto:
VICTOR REINZ Part # W39368TC - Side cover gasket
ACDELCO Part # 8689901 - TCC soleniod
Funny that the pressure switch is hard to find... that was easy when I did it 10 years ago... I had to go to a tranny shop to get the solenoid. LOL
[This message has been edited by carbon (edited 07-19-2013).]
