  stamped 1.6 rockers?
stamped 1.6 rockers? by AL87
Started on: 01-14-2013 11:50 PM
Replies: 12 (482 views)
Last post by: AL87 on 10-12-2014 11:04 PM
AL87
Report this Post01-14-2013 11:50 PM Click Here to See the Profile for AL87Send a Private Message to AL87Edit/Delete MessageReply w/QuoteDirect Link to This Post
who knows what vehicle the 1.6 stamped 60* v6 rockers come out of?
Im seeking a cheap bump in hp since I have to replace my old stamped ones anyways.
3.1?
3100?
what year and model?
[This message has been edited by AL87 (edited 01-15-2013).]
AL87
Report this Post01-15-2013 06:26 PM Click Here to See the Profile for AL87Send a Private Message to AL87Edit/Delete MessageReply w/QuoteDirect Link to This Post
nothing? surely someone has the correct answer.
BillS
Report this Post01-15-2013 06:52 PM Click Here to See the Profile for BillSSend a Private Message to BillSEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just cough up the money for Comp Cams roller rockers, it isn't that much and you get a quality part.
I run them on my 3.2 turbo as well as my 3.4 normally aspirated engines.
AL87
Report this Post01-15-2013 07:36 PM Click Here to See the Profile for AL87Send a Private Message to AL87Edit/Delete MessageReply w/QuoteDirect Link to This Post
im going to the junkyard for these they are stamped... of course Id cough up the money, I just dont want to, not for a stock 2.8
Total ratings: 200
Report this Post01-16-2013 07:13 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
If I can convince you otherwise, it makes a pretty substantial difference in fuel economy, sound, and cooling in the top-end of the engine. The motor also revs up quicker as a result of it having a roller tip.
raysr11
Report this Post01-16-2013 08:36 PM Click Here to See the Profile for raysr11Send a Private Message to raysr11Edit/Delete MessageReply w/QuoteDirect Link to This Post
I bought a set that were for a 3.1 from WOT at the 60 degree V6 forum for my 3.4 hybrid swap. I don't know what they were off of but you could find out there. I had a set of roller tip rockers on the 3.1 in my '86 S10 Blazer and they slid of the valves and rounded the valve tip.
[This message has been edited by raysr11 (edited 01-16-2013).]
NW-Fiero
Report this Post01-16-2013 10:48 PM Click Here to See the Profile for NW-FieroSend a Private Message to NW-FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is a good article on the 1:6 rocker 1994-1995 3.1L engines http://www.tgpforums.com/index.php?topic=3564.0
The 10th digit of the Vin will be "R"(1994) or "S"(1995) on the cars that have these rocker arms. You will need to get the pushrod guide plates from the 94-95 3100 along w/ the rocker arms... also take the pivot balls w/ the rockers, but inspect them for any gouging, etc. beforehand.
Mark
In the Great Northwest!
[This message has been edited by NW-Fiero (edited 01-16-2013).]
AL87
Report this Post04-30-2014 10:42 AM Click Here to See the Profile for AL87Send a Private Message to AL87Edit/Delete MessageReply w/QuoteDirect Link to This Post
you wont have to get anything exept the pivot ball and rocker arm (and maybe the stud and pushrod IF there is a difference)*
the 3100 uses aluminum heads, so the design is different than the fiero's, that is why I'm sure you wouldn't need any of the guides, since they are for a different head design.
trotterlg
Report this Post04-30-2014 11:31 AM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 3100 uses 1.6 stamped rockerarms, the ball type, 10mm shaft I think. I have a set sitting here. And, no, the 3100 guide plates don't fit the iron heads. Larry
[This message has been edited by trotterlg (edited 04-30-2014).]
AL87
Report this Post04-30-2014 01:35 PM Click Here to See the Profile for AL87Send a Private Message to AL87Edit/Delete MessageReply w/QuoteDirect Link to This Post
Alrighty, thanks for the input, I looked at that link and the guys were talking about some of the differences. IF the shaft is 10mm, all the better because that is what the 1st gen (iron head) 60* uses as well.
trotterlg
Report this Post04-30-2014 01:44 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you want a set send me $10.00 and I will ship them. Larry
trotterlg
Report this Post04-30-2014 10:18 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
trotterlg
Member since Aug 2011
Let us know how they fit.
AL87
Report this Post10-12-2014 11:04 PM Click Here to See the Profile for AL87Send a Private Message to AL87Edit/Delete MessageReply w/QuoteDirect Link to This Post
they fit great! no problems, there is a little tang to over the oiling hole on the top of the rocker where the oil from the pushrod comes up from and you can use that as the primary identifier to tell the 1.5 rockers apart from the 1.6 rockers.
I can definitely tell a slight power increase, on the feeling of acceleration.
if someone is going for a budget build on their 2.8-3.4, these would be a great.
