Update System
  Halogen Infra-Red (HIR) headlamp bulbs
Halogen Infra-Red (HIR) headlamp bulbs by fierosound
Started on: 11-15-2012 09:24 PM
Replies: 16 (2315 views)
Last post by: theogre on 08-14-2013 07:18 PM
fierosound
Total ratings: 286
Report this Post11-15-2012 09:24 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
These would not be useful on a Fiero unless you've changed over to a headlamp system that uses the low profile 4-lamp lenses or maybe with Hella 6054 H4 lenses (get to that later).
With my other vehicle I'd been using the up-scale halogens by GE, Sylvania and others. Most are just a higher wattage halogen bulb and the old adage "if you burn twice as bright, you last half as long" is very true. They run $55-70 a pair and have a life span of ONLY 250-300 hours (some even less). Yeah - have them on an hour a day and you'll be burning one out after 10 months. Also while running 100/80 watt bulbs in place of the 65/55 watt stockers looked great, I was concerned about melting the wiring and connector as some have reported.
There were no factory HID lamps for my vehicle that I could acquire and just swap in, so other option - HID bulb kits. There's all kinds of HID kits that run from cheap crap to overly expensive - but most still just stick a HID bulb into your headlamp designed for halogen bulbs. Not ideal because the rear reflectors inside the headlamp are not designed for HID but some swear it works great (as they blind everybody on the street).
While looking around I found these HIR bulbs (bulb on left)
Information
The HIR (Halogen Infra-Red) incandescent light bulb produces 75% of the light output of HID headlights at 25% of the cost. They are a single filament bulb with the same base and o-ring style as a 9005 or 9006 headlight bulb. These bulbs attain light levels 75% to 110% brighter than stock as a result of an engineering process by GE that deposits multiple, yet almost invisible, layers of semi-reflective coating on the surface of a specially shaped quartz bulb. This coating reflects a portion of the infrared energy emitted by the filament back onto the filament, causing it to glow brighter and emit more light from the uncoated forward portion of the bulb. Although the filament gets hotter, the glass does not.
These bulbs generate NO MORE heat than a regular halogen bulb, and they draw the same electrical current as the stock bulbs that they replace. These are a great option if you wish to upgrade your stock 9006 or 9005 halogen bulbs because they will be a near direct plug and play upgrade. The cross reference numbers are: 9005 bulb = 9011 HIR bulb; 9006 bulb = 9012
There's a couple models of cars that had these from the factory.
HIR specs : http://www.headlightservice...oad/HIRspecsheet.pdf
You can buy here I think: http://hirheadlights.com/
My experience:
You can only use HIR bulbs in headlamps with the metal reflector in front of the bulb.
The bulb itself has no "cap" on the end like regular halogens and you'd be blinding oncoming drivers.
My vehicle's headlamps have the internal reflector.
Now these bulbs were developed as a single filament bulb with the filament in the "sweet spot" where the infra-red rays are reflected, so most Forums I found talking about these and the few vendors selling these had the single filament bulbs. My Dodge Caravan has a dual-filament high/low halogen bulb. So I figured that's it - too bad.
BUT I found a source for dual-filament HIR bulbs to fit my vehicle - model 9007/HB5
http://www.limbat.com.sg/products/search
I ordered a set $75 delivered to my door by Fed-ex in 3 days.
Sylvania ZXE run $69 at my local store by comparison (the ones with 250 hour or less lifespan).
Direct fit, installing was a snap. After getting them in and playing with them I found a minor problem.
The high/low was reversed and swapping the wires in the connectors took and extra 5 minutes.
The headamps also need re-aiming, but that was expected.
WOW! I like them.
Not as "white" as the 100/80watt blue-tinted halogens I had been using. Nor as yellow as regular halogens. A good color light - easy to see with.
What is most noticeable is the FLOOD of light across the road in Low beam, and High beams light everything up blocks away.
... and these are only 35/35 watt bulbs but they put out 2300 lumens.
Installed them in September, so only a couple of months so far, but these should last.
I think by switching to Hella headlamps, you could then use the H4 dual-filament HIR bulbs.
Again, it would need to have the reflector in front of the bulb in there. Someone would have to check.
Sorry - don't have any before/after pics of my own.
But I researched this stuff and found these on other forums.
See their pics. I have pretty much the same results as the Corvette.
http://forums.corvetteforum...headlight-bulbs.html
http://g35driver.com/forums...ir-bulbs-anyone.html
http://www.dsmtalk.com/foru...wthread.php?t=174610
[This message has been edited by fierosound (edited 11-16-2012).]
Ang84Indy
Report this Post11-15-2012 11:20 PM Click Here to See the Profile for Ang84IndySend a Private Message to Ang84IndyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the information
FieroBobo
Report this Post11-15-2012 11:25 PM Click Here to See the Profile for FieroBoboSend a Private Message to FieroBoboEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fierosound,
Thanks for sharing you experience with the HIR bulbs.
I'm seriously considering putting a set for HIR bulbs on my 2010 Accord.
The info that you have given makes me much more willing to get up and make the change to the HIR bulbs.
(Maybe I can talk Santa to give me a set. )
~ Bob ~
"Its nice to be important.
Its more important to be nice."
CheshireGrin
Report this Post11-16-2012 12:17 AM Click Here to See the Profile for CheshireGrinSend a Private Message to CheshireGrinEdit/Delete MessageReply w/QuoteDirect Link to This Post
These are also offered by hairballrm in his setups as posted in the mall (sorry can't link from my phone )
Ryan
fierosound
Total ratings: 286
Report this Post11-16-2012 01:19 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Accord guy here http://www.driveaccord.net/...ighlight=sedan+light
He sounds happy.
FieroBobo
Report this Post11-17-2012 12:40 AM Click Here to See the Profile for FieroBoboSend a Private Message to FieroBoboEdit/Delete MessageReply w/QuoteDirect Link to This Post
He sounds happy.
Fierosound,
Thank you. I appreciate you effort to dig up and post the link on my behalf.
You are a true Prince amoung men.
Thanks Again.
~ Bob ~
fierosound
Total ratings: 286
Report this Post11-19-2012 09:54 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
These HIR bulbs should be useful on some cars that have factory HID.
I've seen some that have HID for low beam only and have a halogen bulb for high beam (sometimes the reverse too).
My GF's Infiniti has this, and I've seen a friend's Ford truck with the HID/halogen combination.
Changing out the halogen bulb for an HIR bulb would give you the best of both worlds.
skuzzbomer
Total ratings: 92
Report this Post11-20-2012 12:56 AM Click Here to See the Profile for skuzzbomerSend a Private Message to skuzzbomerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've been planning on doing just that with my daily driver. I'm not too sure it would be worth it in some cases - mine is a toss up since the car already lights up the roadway like a landing pad. It's in the plan for my Fiero, once I get the Hellas installed.
fierosound
Total ratings: 286
Report this Post04-08-2013 11:49 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Update: Installed these in September and still going strong with NO problems.
I'd have had to replace "HID look" 100/80 watt halogen bulbs by now as most have a 300 hour (or less) lifespan.
fierosound
Total ratings: 286
Report this Post08-12-2013 09:04 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's been almost a year with these Hi/Lo HIR technology bulbs snd they are still working great!
In the past I found the "HID Look" bulbs several manufacturers sell last about 3 months or so. Sure they're bright, but they don't last long.
These usually say right on the package they have a 250-300 HOUR lifespan. (about 3 months at 3 hours per day)
And it seems, the old adage is very true "If a bulb burns twice as bright, it will last half as long" (or less).
[This message has been edited by fierosound (edited 08-12-2013).]
Total ratings: 570
Report this Post08-12-2013 11:57 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Even SYLVANIA Silver Star etc has short run time...
code:
H6054     SilverStar XtraVision Standard
low beam 150 440 320
hi beam 50 200 200
list/2 $39.99 $29.99 $19.99
9003/H4
low beam 150 160 1100
hi bean 50 160 230
Life in hours, From SYLVANIA web site
If you have bad grounds etc or iffy alt then most likely you get light bulb problems too.
Added Relays etc is you friend... HL and dimmer switches can get heat damage over time and more bulb amps, the more damage done. Even OE bulbs can cause heat in old worn switches and contacts.
See my Cave, Headlights
sleevePAPA
Report this Post08-12-2013 01:13 PM Click Here to See the Profile for sleevePAPASend a Private Message to sleevePAPAEdit/Delete MessageReply w/QuoteDirect Link to This Post
Interesting that the manufacturer pitches "Infra-Red" even though Infrared is not visible light. lol
fierosound
Total ratings: 286
Report this Post08-12-2013 01:17 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don't need it myself now with HIR, but definitely a good idea for anyone who is going to overload their switches and wiring with other high wattage bulbs.
LOL back at ya...
It's not the Infrared itself, but the effect it has on the filament.
"This coating reflects a portion of the infrared energy emitted by the filament back onto the filament,
causing it to glow brighter and emit more light from the uncoated forward portion of the bulb."
It definitely works "as advertised".
sleevePAPA
Report this Post08-12-2013 01:25 PM Click Here to See the Profile for sleevePAPASend a Private Message to sleevePAPAEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ahh, so basically a short-pass reflective coating.
fierosound
Total ratings: 286
Report this Post08-13-2013 12:34 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Exactly!
You know how it is.
After someone invents the thing, you whack yourself on the side of the head and say "Hey! I could have come up with that!"
[This message has been edited by fierosound (edited 08-13-2013).]
Total ratings: 465
Report this Post08-13-2013 06:36 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ryan
I've got HIRs in my projectors. High beam only.
In another post, I described them as "portable daylight". They're quite nice.
Total ratings: 570
Report this Post08-14-2013 07:18 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Relay can help even when using "Stock" bulbs... (50-65w hi, 35w lo) OE HL and Dimmer does wear... Worn switches build more resistance thus create more contact heat etc.
I use "stock" bulbs (Discontinued Phillips Hi Vis 65/35w lamps) and recently I had to replace the dimmer switch because switch was very warm and toasting the plastic shell. In DE, I rarely use Hi beam because tooo much traffic. New switch and heat is gone.
Relays put power to bulbs with less connections.
Carefully check HL and Dimmer switches. Heat, discolored plastic are signs the switch and/or socket has problems. (discolored plastic on dimmer is hard to see in the car. first plastic area to turn tan/brown is at the connections...)
